ahdoman |
It's phonetic...Ah-D-O-Man (Audioman) ![]() ![]() ![]() Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California ![]() |
Here's the deal; I started a thread over on the PP / 911 site on possibly using coil pack ignition instead of the traditional distributor and wires. In keeping with the 911 wine and cheese tradition it's gone high dollar, twin plug, race motor setups. (I should have known better than to try to get "shade tree mechanic" info from the "executive" class).
So, here's where I am so far and I'm hoping some of you can fill in the info here. Since most of you are on a budget like me I thought I'd get some more realistic answers over here. There are several manufacturers of coils that fit on the top of the plugs (Audi, VW, Kawasaki, Denso, etc.). These are really cool because they also fit down into the sheet metal of the 4's but in my case the valve covers and headsof the /6. It also means the elimination of plug wires and puts a nice strong spark right at the plug. What I am trying to understand is the other parts that are needed to complete a system. I know there are some good manufacturers of pre-fabed solutions out there but they are $$$$$$$$$$ and still require plug wires to be run from a central coil pack location. Here's a couple of questions; 1) I realize that the individual coil packs will need to be triggered. What are the options to doing this and how are they wired? 2) What kind of a "brain" needs to be involved with a system like this? What does it need to do? Here's an example of the type of coil pack I'm looking at... ![]() And here's an example installed... ![]() See how neat that is? I realize wires will still need to be run but they can be much smaller since they no longer need to carry the voltage from the coil. |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
Guess it's time to chime in again. I don't know 'bout the performance advantage of coil packs, although I am doing one now. I do know that with the Megasquirt 2 unit i'm running, using it to control timing on the dizzy set up, it works very well. I've notice much smoother throttle response and can run a little more advance under normal loads, them being able to back it down under heavy loads. Also runnng a little more advance at high RPM range, this is all with the bus 2.0. It bounces right to 5500 rpm before the hydro lifters go away. Can't wait to build the GA motor for it. Guess what i'm saying is just the fact you can change/tune your timing from a laptop is very nice.
Lo-Fi Version | Time is now: 9th July 2025 - 04:49 PM |
