Engine backfires, Suggestions for 2.0 carb motor |
RWD |
Feb 22 2004, 06:55 PM
Newbie Group: Members Posts: 4 Joined: 22-February 04 From: Staten Island, NewYork Member No.: 1,701 |
Hi all,
Just found this forum. Wish there would have been something like it when I started restoring my 73 2 liter back in 1980. Anyhow still have, and love the car! Here is my question , why is my car backfiring when shutting the engine off?Is there something going on with the carb conversion (dual 40 IDF's) that I did many many years ago. Checked timing, plugs, carb balance etc.. I don't have any gaskets where the manifolds come in contact with the heads, only on the top where the carb meets the manifold. Could this backfires indicate an air leak of some sort, and if so what is the best material or sealant to eliminate it. Any suggestions would be helpful. (IMG:style_emoticons/default/confused24.gif) |
Joe Ricard |
Feb 22 2004, 07:42 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
You can cut some gaskets from sheet material from your local FLAPS. Put gasket material on manifold end and lightly tap around the edges with a ball peen hammer then cut with a razor.
You will have a significant increase in idle speed and you will need to ajust the throttle plates. If I recall there should only be like a few thousandths between the butterfly and the bore wall. Back fires should stop too. |
Lo-Fi Version | Time is now: 16th June 2024 - 06:19 AM |
