Shock Options full race, What are you running? |
Heeltoe914 |
Jul 17 2009, 11:59 AM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
Setup is full simi tube car 1775 appox, 10 and 12 LSD Boxster brakes Combo of high speed tracks and AX. Driving.
Hi guys starting stage three of the upgrades to my Spyder racecar. I am planning to add Adjustable front and rear shocks. The front should not be such a big deal the shocks on the car now are made by a Company called Carrera Shocks. The front’s inserts are much shorter than a Carrera or SC size inserted shock. It’s about 10.5 inch long. The rears are short about 12.5 “. If you notice the rear shocks are inverted, I would like to find something that will mount with the shock bolt and damper location. What makes finding a replacement a challenge is that the stub that is welded onto my rear shocks is not commonly done and would have to be done before the shock is constructed. I would think that there are other ways of getting a inverted shock on a 914 using stock mounting locations. Advice or suggestion welcomed. Part two; Another question I have is if you have a track only racecar that ran as a high output four banger with a very good setup, than converted it to a 3.6 which adds some weight & HP what guess would you make on how much to go up on front and or rear spring rates??? I am thinking 50pds per corner just for the weight but I need to add in the hard acceleration and cornering as well. What has anyone here tried? Attached image(s) |
ME733 |
Dec 14 2009, 09:17 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
(IMG:style_emoticons/default/popcorn[1].gif) ...Chris ...I have a set of CARRERA shocks very similar to the ohlins. There is a "srader valve", air inflator valve at the bottom of the shock absorber, where your pressure line is. They have a 5.5'' stroke......my question is , how will you adapt the top mounting heim-joint to the O.E.M. top shock mount...and where do you "recharge "the cannister, I don't see a fitting....a suggestion as to springs/ rate would be appreciated..( stock street 914 about 2100 lbs.1973..2.o)....murray... (IMG:style_emoticons/default/popcorn[1].gif)
ChrisFoley |
Dec 14 2009, 12:13 PM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
(IMG:style_emoticons/default/popcorn[1].gif) ...Chris ...I have a set of CARRERA shocks very similar to the ohlins. similar in that they have a threaded body and are nitrogen charged... QUOTE ...my question is , how will you adapt the top mounting heim-joint to the O.E.M. top shock mount... You can but adaptors for about $200 from The Racers Group, Rebel Racing, and probably others. I don't have oem shock towers so I will be making something myself. QUOTE ...and where do you "recharge "the cannister, I don't see a fitting... There is a fill valve on the end of the canister that you can't see in the pic. QUOTE ...a suggestion as to springs/ rate would be appreciated..( stock street 914 about 2100 lbs.1973..2.o)....murray... (IMG:style_emoticons/default/popcorn[1].gif) 140-150 lb |
Lo-Fi Version | Time is now: 11th June 2024 - 03:31 AM |
