Shock Options full race, What are you running? |
Heeltoe914 |
Jul 17 2009, 11:59 AM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
Setup is full simi tube car 1775 appox, 10 and 12 LSD Boxster brakes Combo of high speed tracks and AX. Driving.
Hi guys starting stage three of the upgrades to my Spyder racecar. I am planning to add Adjustable front and rear shocks. The front should not be such a big deal the shocks on the car now are made by a Company called Carrera Shocks. The front’s inserts are much shorter than a Carrera or SC size inserted shock. It’s about 10.5 inch long. The rears are short about 12.5 “. If you notice the rear shocks are inverted, I would like to find something that will mount with the shock bolt and damper location. What makes finding a replacement a challenge is that the stub that is welded onto my rear shocks is not commonly done and would have to be done before the shock is constructed. I would think that there are other ways of getting a inverted shock on a 914 using stock mounting locations. Advice or suggestion welcomed. Part two; Another question I have is if you have a track only racecar that ran as a high output four banger with a very good setup, than converted it to a 3.6 which adds some weight & HP what guess would you make on how much to go up on front and or rear spring rates??? I am thinking 50pds per corner just for the weight but I need to add in the hard acceleration and cornering as well. What has anyone here tried? Attached image(s) |
J P Stein |
Dec 14 2009, 07:09 PM
Hayden says the Fox are way too stiff for a 914 AXer.
SirAndy |
Dec 14 2009, 07:15 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Hayden says the Fox are way too stiff for a 914 AXer. Kinda what i was thinking. A light AX 914 could be 800lbs lighter than the Spec 911 ... (IMG:style_emoticons/default/santa_smiley.gif) Andy |
J P Stein |
Dec 14 2009, 09:17 PM
Hayden says the Fox are way too stiff for a 914 AXer. Kinda what i was thinking. A light AX 914 could be 800lbs lighter than the Spec 911 ... (IMG:style_emoticons/default/santa_smiley.gif) Andy I test drove a 914 vintage race car on our AX venue last summer. A friend was thinkin' about buying it. It was totally unsuitable for AX at any venue I've driven with the possible exception of Marina. It literally bounced across the bumps. The fella does fine on the big track at PIR.....that track is smooth as a baby's ass. My buddy got scared off by it.... tho I assured him it could be set up to run with practically no out-of pocket- expenses....there was a ton of valuable extras. It had a lot more motor than mine but the power band was wrong for AX.....that is a relatively easy fix. |
Randal |
Dec 14 2009, 10:28 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Hayden says the Fox are way too stiff for a 914 AXer. Kinda what i was thinking. A light AX 914 could be 800lbs lighter than the Spec 911 ... (IMG:style_emoticons/default/santa_smiley.gif) Andy I test drove a 914 vintage race car on our AX venue last summer. A friend was thinkin' about buying it. It was totally unsuitable for AX at any venue I've driven with the possible exception of Marina. It literally bounced across the bumps. The fella does fine on the big track at PIR.....that track is smooth as a baby's ass. My buddy got scared off by it.... tho I assured him it could be set up to run with practically no out-of pocket- expenses....there was a ton of valuable extras. It had a lot more motor than mine but the power band was wrong for AX.....that is a relatively easy fix. OK gentlemen, what front shocks will work best with Chris's back ones and what needs to be done with them to make them work in a light front end car? |
ChrisFoley |
Dec 15 2009, 09:29 AM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Lo-Fi Version | Time is now: 11th June 2024 - 09:59 AM |
