> 75 1.8 garage find won't start
jhelgesen
post Dec 12 2009, 08:42 PM
(IMG:http://i184.photobucket.com/albums/x311/jhelgesen/75%20914/DSCN5132.jpg)
I'm trying to resurrect a 75 1.8 thats been sitting for 15 years. (she was hiding in a basement next to the furnace for all that time). Pretty darn rust free as far as 914's go. She got parked for FI issues.
(IMG:http://i184.photobucket.com/albums/x311/jhelgesen/75%20914/DSCN5141.jpg)
I'm trying to get her running again. I've got the tank clean. The fuel pump was cleaned and runs. The fuel injectors have been cleaned and checked, click well. Dual relay clicks when attempting to start. She turns over, but I'm not getting power to the fuel injectors. What to I try next?
Thanks,
computers4kids
post Dec 15 2009, 08:42 AM
Love these little cars!
My 74 Ljet has only has two relays and one does run the heater. Clay I know you know the in and outs of Ljet very well, but I'm pretty sure my L-jet has to have at least the one relay to startup and run. You have me curious now. I'll have to pull my two relays and see what happens. Even though when I cleaned the blue 25 amp the car still just cranked and cranked, perhaps it was a delay re-action. It's been a long time since I've had an L-Jet.
ClayPerrine
post Dec 15 2009, 08:52 AM
QUOTE(computers4kids @ Dec 15 2009, 08:42 AM) *
You shouldn't need the fuse either. All of the power for the L-jet system comes from the power feed wire that runs between the double relay and the battery.
davesprinkle
post Dec 15 2009, 11:15 AM
QUOTE(ClayPerrine @ Dec 15 2009, 06:52 AM) *
Clay is correct here. The Ljet system pulls its power directly from the positive lead of the battery, bypassing the fuse on the relay board.
The Ljet wiring is a poor design for a number of reasons; the main one being: IT HAS NO FUSE. I strongly recommend adding an in-line fuse to the double-relay battery supply lead.
jhelgesen   75 1.8 garage find won't start   Dec 12 2009, 08:42 PM
Mark Henry   Your story is very much like my '74, with mine...   Dec 13 2009, 04:50 AM
type47   There is a tool called a "noid" that wil...   Dec 13 2009, 06:56 AM
7275914911   There is a tool called a "noid" that wi...   Dec 13 2009, 07:15 AM
jim912928   another key to the L-jet fuel injection is the Mas...   Dec 13 2009, 09:12 AM
ClayPerrine   another key to the L-jet fuel injection is the Ma...   Dec 13 2009, 10:21 AM
stepuptotheMike   :wavebye:   Dec 13 2009, 10:46 AM
davesprinkle   Another thing to consider -- the Ljet brain requir...   Dec 13 2009, 10:50 AM
jhelgesen   I have continuity to the resisters and they show a...   Dec 13 2009, 11:16 AM
jim912928   Clay...info I got was from a Porsche mechanic who ...   Dec 13 2009, 12:24 PM
jhelgesen   Next step I'll check the coil and plugs. When...   Dec 13 2009, 12:52 PM
type47   It should be easy enough to put an inductive timin...   Dec 13 2009, 01:14 PM
messix   point gap/dwell?   Dec 13 2009, 01:24 PM
davesprinkle   point gap/dwell? I agree. Sounds to me like yo...   Dec 13 2009, 03:18 PM
jd74914   I too am thinking you don't have a functioning...   Dec 13 2009, 03:24 PM
jhelgesen   Timing light shows no spark....lets see what I can...   Dec 13 2009, 03:32 PM
jhelgesen   Can't get power to the ignition. Jumpered a w...   Dec 13 2009, 05:16 PM
jhelgesen   Put in new points tonight. I now have power at th...   Dec 14 2009, 08:32 PM
r_towle   Back up. Pardon me if I am brief... We need to ext...   Dec 14 2009, 08:44 PM
jhelgesen   Good plan Rich, thanks, I'll start again.   Dec 14 2009, 09:02 PM
ahdoman   Also check the 2 fuses on the relay panel. I belie...   Dec 14 2009, 09:10 PM
ClayPerrine   Clay...info I got was from a Porsche mechanic who...   Dec 14 2009, 09:43 PM
computers4kids   Clay...info I got was from a Porsche mechanic wh...   Dec 14 2009, 10:26 PM
ClayPerrine   [quote name='ClayPerrine' post='1250674' date='De...   Dec 15 2009, 07:30 AM
jhelgesen   Does someone have this picture for a 75 1.8 car? ...   Dec 15 2009, 06:38 AM
type47   The factory workshop manual shows 3 relay boards, ...   Dec 15 2009, 07:19 AM
computers4kids   My 74 Ljet has only has two relays and one does ru...   Dec 15 2009, 08:42 AM
ClayPerrine   My 74 Ljet has only has two relays and one does r...   Dec 15 2009, 08:52 AM
zonedoubt   :agree: To understand how the double relay works,...   Dec 15 2009, 10:27 AM
davesprinkle   You shouldn't need the fuse either. All of t...   Dec 15 2009, 11:15 AM
ClayPerrine   You shouldn't need the fuse either. All of ...   Dec 15 2009, 02:42 PM
Dave_Darling   My 74 Ljet has only has two relays and one does r...   Dec 16 2009, 11:15 PM
jhelgesen   Super! Thanks,   Dec 15 2009, 10:51 AM
jhelgesen   Didn't make it past step one. No pump running...   Dec 15 2009, 07:37 PM
ClayPerrine   Didn't make it past step one. No pump runnin...   Dec 15 2009, 09:54 PM
r_towle   you stated that the fuel pump runs when you run it...   Dec 15 2009, 08:15 PM
jhelgesen   Tested power at the pump this morning. I got powe...   Dec 16 2009, 06:39 AM
jhelgesen   Still trying to start the motor without success. ...   Dec 18 2009, 07:23 AM
7275914911   Still trying to start the motor without success. ...   Dec 18 2009, 01:06 PM
jhelgesen   This morning, I broke down and sucked the smidgen ...   Dec 19 2009, 11:06 AM
ClayPerrine   This morning, I broke down and sucked the smidgen...   Dec 19 2009, 04:45 PM
jhelgesen   Okay, I'm getting close. One the phone last n...   Dec 20 2009, 10:46 AM
jhelgesen   Ah the web is a wonderful thing.... http://i184.p...   Dec 20 2009, 10:56 AM
RRietman   John; With ign on, you should have 12v to the inje...   Dec 20 2009, 11:36 AM
jhelgesen   :Qarl: :cheer: :headbanger: Picked up a handfu...   Dec 20 2009, 04:13 PM
wrightee   Here is the offending resistor. and my temporar...   Dec 20 2009, 05:03 PM
stepuptotheMike   Sweetness John! Good to hear you got it runni...   Dec 20 2009, 04:54 PM
jhelgesen   The resistor is in the fuel pump relay, circuit fr...   Dec 20 2009, 05:14 PM
type47   Wow... fixing a resistor in a relay, :worship:   Dec 20 2009, 06:27 PM
ClayPerrine   You need to buy a replacement double relay, if onl...   Dec 20 2009, 09:10 PM
davesprinkle   Good job tracking down and fixing that problem. E...   Dec 20 2009, 10:03 PM
computers4kids   and, believe it or not, the seal under the oil fil...   Dec 20 2009, 10:55 PM
ClayPerrine   So your problem was the same as mine, a bad relay...   Dec 21 2009, 07:47 AM
computers4kids   So your problem was the same as mine, a bad rela...   Dec 21 2009, 09:19 AM
jhelgesen   I have a new relay on order, along with a handfull...   Dec 21 2009, 03:20 AM
jhelgesen   This afternoon, we opened the garage door, started...   Dec 24 2009, 07:20 PM
- Lo-Fi Version Time is now: 26th June 2026 - 10:37 PM
