Corner Weight Balancing of 914s, The benefits of equalizing the side-to-side corner wts. |
stewteral |
Dec 9 2009, 12:43 AM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Hey 914ers:
If you have been following my posts on 914 chassis settings, here is one that applies to ALL 914's. To start, per my posts: -I Squared the chassis with paralleled strings to measure and set the toe, front and rear. (Front = 0 to -1/16 toe, rear = 0 to -1/8" toe) =Results: steering a bit "nervous", but all else stable. -Camber: For Street cars, Standard front with -1 to -1.5 degrees rear. =Results: nothing noticeable. -I bumpsteered the front suspensions to within 0.008" from prefect at 2" compression. =Results: nothing I could feel driving the car on the street. TBD on-track. -CORNER WEIGHT BALANCED THE CHASSIS: With the car weighted for the driver weight, I adjusted the rear spring ht. and the front torsion bar ride height. For the rear, large diameter washers can be added to make adjustments, while the front is too easy with an 11 mm wrench. =Results: WONDERFUL!! With all the previous chassis settings done, the car still wanted to pull to the right as though I were on a highly crowned road. After the balancing the corner weights, side-to-side, the car now runs STRAIGHT and TRUE right down the road. The sense through the steering is now light, equal and very linear as to where I want to aim the car. Conclusion: Take the time to either build wt check lever, as per my photo or find a very strong STEEL ladder and wing it. Regardless, the benefit from the effort is completely WORTH IT!!! If you have any questions, please let me know! Terry stewteral@verizon.net |
J P Stein |
Dec 17 2009, 06:24 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
A man's got to know his limitations.
stewteral |
Dec 17 2009, 09:50 PM
A man's got to know his limitations. JP Stein: So your "racing experience" is 10 years with a slalom car? Did you do any of the driving, or just the wrenching? Did the car ever get to a race track? Why is the front-end so stiff on the slalom car that the inside front wheel is lifted of the ground? Is that to compensate for an open Diff in order to put the power down? Best, Terry |
J P Stein |
Dec 17 2009, 10:26 PM
JP Stein: So your "racing experience" is 10 years with a slalom car? Did you do any of the driving, or just the wrenching? Did the car ever get to a race track? Why is the front-end so stiff on the slalom car that the inside front wheel is lifted of the ground? Is that to compensate for an open Diff in order to put the power down? Best, Terry Yes, autocross for 10 years & yes I drove it all that time...if not well. It has a Guard TB diff & the rear is so soft that the inside front lifts off the ground under power. It has to be fairly soft as AX venues are not smooth for the most part. Did a DE years back. Since I couldn't afford to do W2W went to Autocross where there is competition. I could see no sense driving around a race track pertending to be a race car driver. You should try AX...who knows, you may have the only V8 914 that handles worth spit. It's also a good place learn car control. |
Lo-Fi Version | Time is now: 5th June 2024 - 08:47 PM |
