| ME733 |
Dec 15 2009, 01:29 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
(IMG:style_emoticons/default/popcorn[1].gif) well gang just reciently there have been some posts about carburator jets, air correction jets,jet carrier, and their location, and how to read them. My question is this. For those who have measured /verified /checked the accuracy of Jets, (both air and mains) who would you recommend , and who would you purchase them from?. I ask the question because some "new" jets I have collected are a little off. examples, 120,s were 130,s, 125,s were 135,s, 130,s were 145,s...etc., it,s easy enough to drill out a small jet and make it larger.(with jet drills) but this doesn't work in reverse naturally. So who would you recommend for new accurate Jets! or other accurately made carburator parts. (IMG:style_emoticons/default/popcorn[1].gif)
| DBCooper |
Dec 18 2009, 11:57 AM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Hmmm... That's how I've done it for about four decades now, on my own and on customer's cars. Good to find out it doesn't work. Thanks.
Still scratching my head though. I'm aware of no way to get a more accurate hole than with a drill index. If you use the same drill in each hole how could they end up being different? And if you can't solder then of course the best advice is "don't". The wide band tells you how the MOTOR is running, rich or lean, in different running situations, so it has to be in merged exhaust flow. You jet each throat the same, so the whole engine is in balance. You could jet each barrel individually, I suppose, but I don't know anyone who does, or why they would. |
ME733 carburator jets Dec 15 2009, 01:29 PM
tat2dphreak aircooled.net
aircooled also has mid sizes like ... Dec 15 2009, 01:38 PM
9146986 If there's any question you can check the jets... Dec 15 2009, 08:52 PM
GeorgeRud Don't know if he's still doing it, but Ric... Dec 15 2009, 09:23 PM
jmill I like Pegasus. http://www.pegasusautoracing.com/... Dec 15 2009, 10:30 PM
type2man http://www.cbperformance.com/category.asp?Category... Dec 15 2009, 10:58 PM
jaxdream You could also do what a guy I know used to do to ... Dec 16 2009, 12:09 AM
DBCooper
You could also do what a guy I know used to do to... Dec 16 2009, 06:58 AM
Mark Henry I've been tuning with a wide band and jet dril... Dec 16 2009, 07:10 AM
sean_v8_914 I'll second that!!! get access to ... Dec 16 2009, 07:25 AM
jaxdream I would venture to say that I am very ignorant whe... Dec 16 2009, 10:29 AM
jmill This is what I have. It's older than dirt but... Dec 16 2009, 10:38 AM
jaxdream That's great , exactly how do you hook it up ?... Dec 16 2009, 10:43 AM
jmill This one does the same thing. You slide the probe... Dec 16 2009, 12:18 PM
charliew I don't live in town and soldering jets always... Dec 16 2009, 01:20 PM
Mark Henry Wide Band O2 meter, sensor goes in the exhaust, ha... Dec 16 2009, 04:22 PM
jmill My old heathkit is a narrow band and it does react... Dec 16 2009, 04:43 PM
jaxdream Thanks guys , went to evil-bay , found a couple of... Dec 16 2009, 09:30 PM
Mark Henry Personally I'd pony up and get a wide band. I ... Dec 17 2009, 10:26 AM
DBCooper +1 Dec 17 2009, 10:28 AM
brant anybody willing to explain the soldering technique... Dec 17 2009, 10:54 AM
Mark Henry
- I have jet measuring tools... but where do I... Dec 18 2009, 06:36 AM
jmill Pliers are big heat sinks. Hold the jet in a vice... Dec 17 2009, 11:23 AM
ME733 :popcorn: ....well guys, I was sorta hoping that t... Dec 18 2009, 07:06 AM
Mark Henry Man sometimes I think this guy is Alfred :idea: Dec 18 2009, 11:32 AM
tat2dphreak
... Dec 18 2009, 12:00 PM
jmill
Still scratching my head though. I'm aware o... Dec 18 2009, 02:20 PM
DBCooper Quibbles. Certainly you could do better with a la... Dec 18 2009, 04:03 PM
Mark Henry My set is reamers not drill bits.
Almost all tune... Dec 18 2009, 04:18 PM
Joe Ricard I put a straight pipe on my tangerine tubed 2316-2... Dec 18 2009, 05:30 PM
scotty b hot glue and a sewing needle does the trick for me... Dec 18 2009, 09:03 PM
ME733 hot glue and a sewing needle does the trick for me... Dec 19 2009, 12:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2026 - 05:50 AM |
