> carburator jets, accuracy of carburator jets.
ME733
post Dec 15 2009, 01:29 PM
(IMG:style_emoticons/default/popcorn[1].gif) well gang just reciently there have been some posts about carburator jets, air correction jets,jet carrier, and their location, and how to read them. My question is this. For those who have measured /verified /checked the accuracy of Jets, (both air and mains) who would you recommend , and who would you purchase them from?. I ask the question because some "new" jets I have collected are a little off. examples, 120,s were 130,s, 125,s were 135,s, 130,s were 145,s...etc., it,s easy enough to drill out a small jet and make it larger.(with jet drills) but this doesn't work in reverse naturally. So who would you recommend for new accurate Jets! or other accurately made carburator parts. (IMG:style_emoticons/default/popcorn[1].gif)
jmill
post Dec 18 2009, 02:20 PM
Green Hornet
QUOTE(DBCooper @ Dec 18 2009, 11:57 AM) *
Still scratching my head though. I'm aware of no way to get a more accurate hole than with a drill index.
You could jet each barrel individually, I suppose, but I don't know anyone who does, or why they would.
Working in the aircraft industry for years I can tell you that a drill bit won't drill the same size hole twice. Most drill bits create a triangle like hole anyhow. Also the run-out on most drill presses stink for accurate jet work. If you set the jet up in a mini lathe and step up the hole with reamers I'd run them. I don't have the right size reamers or a mini lathe so I just buy new.
There's folks out there who jet each barrel individually. Most use EGT not a wideband. I don't get that deep into it and run with the average of all 4. It's close enough for the girls I run with.
ME733   carburator jets   Dec 15 2009, 01:29 PM
tat2dphreak   aircooled.net aircooled also has mid sizes like ...   Dec 15 2009, 01:38 PM
9146986   If there's any question you can check the jets...   Dec 15 2009, 08:52 PM
GeorgeRud   Don't know if he's still doing it, but Ric...   Dec 15 2009, 09:23 PM
jmill   I like Pegasus. http://www.pegasusautoracing.com/...   Dec 15 2009, 10:30 PM
type2man   http://www.cbperformance.com/category.asp?Category...   Dec 15 2009, 10:58 PM
jaxdream   You could also do what a guy I know used to do to ...   Dec 16 2009, 12:09 AM
DBCooper   You could also do what a guy I know used to do to...   Dec 16 2009, 06:58 AM
Mark Henry   I've been tuning with a wide band and jet dril...   Dec 16 2009, 07:10 AM
sean_v8_914   I'll second that!!! get access to ...   Dec 16 2009, 07:25 AM
jaxdream   I would venture to say that I am very ignorant whe...   Dec 16 2009, 10:29 AM
jmill   This is what I have. It's older than dirt but...   Dec 16 2009, 10:38 AM
jaxdream   That's great , exactly how do you hook it up ?...   Dec 16 2009, 10:43 AM
jmill   This one does the same thing. You slide the probe...   Dec 16 2009, 12:18 PM
charliew   I don't live in town and soldering jets always...   Dec 16 2009, 01:20 PM
Mark Henry   Wide Band O2 meter, sensor goes in the exhaust, ha...   Dec 16 2009, 04:22 PM
jmill   My old heathkit is a narrow band and it does react...   Dec 16 2009, 04:43 PM
jaxdream   Thanks guys , went to evil-bay , found a couple of...   Dec 16 2009, 09:30 PM
Mark Henry   Personally I'd pony up and get a wide band. I ...   Dec 17 2009, 10:26 AM
DBCooper   +1   Dec 17 2009, 10:28 AM
brant   anybody willing to explain the soldering technique...   Dec 17 2009, 10:54 AM
Mark Henry   - I have jet measuring tools... but where do I...   Dec 18 2009, 06:36 AM
jmill   Pliers are big heat sinks. Hold the jet in a vice...   Dec 17 2009, 11:23 AM
ME733   :popcorn: ....well guys, I was sorta hoping that t...   Dec 18 2009, 07:06 AM
Mark Henry   Man sometimes I think this guy is Alfred :idea:   Dec 18 2009, 11:32 AM
tat2dphreak   Man sometimes I think this guy is Alfred :idea: ...   Dec 18 2009, 12:00 PM
DBCooper   Hmmm... That's how I've done it for about...   Dec 18 2009, 11:57 AM
jmill   Still scratching my head though. I'm aware o...   Dec 18 2009, 02:20 PM
DBCooper   Quibbles. Certainly you could do better with a la...   Dec 18 2009, 04:03 PM
Mark Henry   My set is reamers not drill bits. Almost all tune...   Dec 18 2009, 04:18 PM
Joe Ricard   I put a straight pipe on my tangerine tubed 2316-2...   Dec 18 2009, 05:30 PM
scotty b   hot glue and a sewing needle does the trick for me...   Dec 18 2009, 09:03 PM
ME733   hot glue and a sewing needle does the trick for me...   Dec 19 2009, 12:36 PM
- Lo-Fi Version Time is now: 29th April 2026 - 05:49 AM
