> Timing your V8-914 / ATT: V8 Guys!, any body got any good hints or suggestions?
wallys914
post Dec 20 2009, 05:31 PM
In life you don't get what you want, you get what you negoia
I set my motor up and everything is running great, but I can feel a like it has a lil hesitation.Without throwing a light on it, I cant get rid of it. I know that the distributor is off, just enough to effect perfection.
How have the V8 guys set up there 914's so that they can time them with easy?
Thanks,
messix
post Dec 20 2009, 06:56 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
hesitation when? tip in no load? part throttle cruise? heavy acceleration? what carb are you running?
TC 914-8
post Dec 20 2009, 10:24 PM
QUOTE(messix @ Dec 20 2009, 04:56 PM) *
Troy is on to something, we need more info. Also I agree with " Cheapsnake" It is probally a carb issue.
I have the same hesitation when I'm at cruse then punch it too fast. Something I live with, Accelerate smothely.
I also use the Vaccume timming method, get the highest vaccume at idle then back it down 1". Also in the Rod Simpson install handbook.
computers4kids
post Dec 21 2009, 09:30 AM
Love these little cars!
QUOTE(TC 914-8 @ Dec 20 2009, 08:24 PM) *
Intitially, I tried to time my engine with a light, and I thought I was giving it plenty of advance. I drove the the car for quite a while like this. Thanks to Tony (TC 914-8), I tried timing a while back using the vaccum method...huge difference in performance---my motor needed a ton more initial advance. However, my car didn't have hesitation issues. I also purchased an adjustable vaccum advance thinking I was going to adjust the curve along with diff. dizzy weights, but the car ran so great after the timing change I just left it alone.
You're problem sounds more related to fuel. If you can't sort it out, you might consider adding a air fuel mixture gauge (even temporarily) and drive your car under a lot of conditions and see what the mixture is doing when you experience the hesitation.
Give us more info...
wallys914   Timing your V8-914 / ATT: V8 Guys!   Dec 20 2009, 05:31 PM
Cheapsnake   Unless your advance curve is woefully flat I would...   Dec 20 2009, 06:53 PM
messix   hesitation when? tip in no load? part throttle cru...   Dec 20 2009, 06:56 PM
TC 914-8   hesitation when? tip in no load? part throttle cr...   Dec 20 2009, 10:24 PM
messix   hesitation when? tip in no load? part throttle c...   Dec 21 2009, 12:44 AM
TC 914-8   [quote name='TC 914-8' post='1253294' date='...   Dec 21 2009, 07:58 PM
computers4kids   hesitation when? tip in no load? part throttle c...   Dec 21 2009, 09:30 AM
kg6dxn   Get a vacuum gauge. connect to the intake, move di...   Dec 20 2009, 09:37 PM
wallys914   Thanks guys I will take a look at the fuel deliver...   Dec 21 2009, 06:39 PM
messix   Thanks guys I will take a look at the fuel delive...   Dec 21 2009, 07:04 PM
TC 914-8   What is this "Dizzy" you talk about ? So...   Dec 21 2009, 07:38 PM
marks914   advance the timing until you have a ping, then bac...   Dec 21 2009, 08:17 PM
wallys914   You guys think the NOS will blow the trans? Even i...   Dec 21 2009, 09:13 PM
TC 914-8   You guys think the NOS will blow the trans? Even ...   Dec 21 2009, 10:50 PM
marks914   You guys think the NOS will blow the trans? Even ...   Dec 22 2009, 07:27 AM
Rand   Sounds like you have a handle on it Wally. I'm...   Dec 21 2009, 09:38 PM
JDJim   Sounds like you have a handle on it Wally. I...   Dec 21 2009, 10:16 PM
wallys914   :mellow: All Valid Points! I will take the NO...   Dec 22 2009, 03:01 PM
messix   no2 builds big tourque as soon as it hits, think a...   Dec 22 2009, 03:47 PM
- Lo-Fi Version Time is now: 8th November 2026 - 03:49 PM
