Rust |
Rust |
bwillis |
Dec 21 2009, 08:58 AM
Newbie Group: Members Posts: 16 Joined: 1-December 09 From: SC Member No.: 11,088 Region Association: None |
So I'm looking at possibly buying this car, it's about 3 hours away from me so I'm only seeing pictures of it right now.
These two pictures obviously make me cringe knowing that there's bound to be more rust behind the jack plates. But, I thought Id see what everyone else thought. Ben Attached image(s) |
goodwood73 |
Dec 21 2009, 09:18 AM
Wherever you go, There you are. Group: Members Posts: 40 Joined: 3-July 05 From: Woodstock, GA Member No.: 4,368 |
That is a common place of rust and a easy fix by just looking from the outside. Problem is that the rust starts inside the hollow frame. You need to do a sag test to determine how bad the structural damage is. The hose and wire should not be there on the passenger side. We need hell hole pictures as well.
Paul |
bwillis |
Dec 21 2009, 11:13 AM
That is a common place of rust and a easy fix by just looking from the outside. Problem is that the rust starts inside the hollow frame. You need to do a sag test to determine how bad the structural damage is. The hose and wire should not be there on the passenger side. We need hell hole pictures as well. Paul That hose and wire are for the dealer installed A/C..... |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:00 PM |
