Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
What is the normal practice in terms of inspecting the case halves prior to a rebuild? Is this something I can do myself?
All the bearing surfaces looked fine and the connecting rod play was between .008 and .010. Assuming I don't see any visual signs of damage, does it need to be sent to a professional who I assume has an expensive tool that checks the alignbore? |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
What is the normal practice in terms of inspecting the case halves prior to a rebuild? Is this something I can do myself? All the bearing surfaces looked fine and the connecting rod play was between .008 and .010. Assuming I don't see any visual signs of damage, does it need to be sent to a professional who I assume has an expensive tool that checks the alignbore? Now i have not done a type 4 yet, did a T1 years ago. Worked in high school as a automotive machinist ( couldn't stand that dirty loose tolerance stuff ! ) but .008 to .010 sounds like a lot of clearance to me. I would think .002-.004 would be more the norm. Maybe i'm wrong again, i'm used to working on .00001 of an inch stuff now. |
Lo-Fi Version | Time is now: 1st July 2025 - 04:46 PM |
