| wallys914 |
Dec 20 2009, 05:31 PM
In life you don't get what you want, you get what you negoia ![]() ![]() Group: Members Posts: 190 Joined: 10-October 08 From: Garden Grove, Member No.: 9,631 Region Association: Southern California |
I set my motor up and everything is running great, but I can feel a like it has a lil hesitation.Without throwing a light on it, I cant get rid of it. I know that the distributor is off, just enough to effect perfection.
How have the V8 guys set up there 914's so that they can time them with easy? Thanks, |
| wallys914 |
Dec 21 2009, 06:39 PM
Thanks guys I will take a look at the fuel delivery. To give a little more info on the carb and motor it is a 650 dp mech sec over proformer RPM manifold, into a 88 350 with a 488 cam with MSD ignition and Dizzy, eventually on 100 shot of N2O. The carb is brand spanking new as well as the MSD set up. I really have only timed it by ear, so that's why I feel like the timing would fix the major issues. I want to get it timed so I can try the Nitrious out... (IMG:style_emoticons/default/biggrin.gif)
I think I will try COMP4KIDS idea about the air/fuel gauge Might be good with the Nitrious anyways (IMG:style_emoticons/default/rolleyes.gif) ... and then try the vacuum timing procedure. Thanks again... |
| messix |
Dec 21 2009, 07:04 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
Thanks guys I will take a look at the fuel delivery. To give a little more info on the carb and motor it is a 650 dp mech sec over proformer RPM manifold, into a 88 350 with a 488 cam with MSD ignition and Dizzy, eventually on 100 shot of N2O. The carb is brand spanking new as well as the MSD set up. I really have only timed it by ear, so that's why I feel like the timing would fix the major issues. I want to get it timed so I can try the Nitrious out... (IMG:style_emoticons/default/biggrin.gif) I think I will try COMP4KIDS idea about the air/fuel gauge Might be good with the Nitrious anyways (IMG:style_emoticons/default/rolleyes.gif) ... and then try the vacuum timing procedure. Thanks again... if your gonna hit it with no2 you will need to pull timing out of it, or get a timing retard that is triggered when the no2 is on. do some research on it or you will frag the motor [not all at once but over time]. the dp is most likely going to give you fits on the street and a vac secondary would be tamer. and the cam is 488 lift? what is the .05 duration? you can play with the accelarator pump cam [the plastic thingy by the throttle linkage that pushed the pump arm] it will have a couple of screw holes for different settings. and does the carb have idle mixture screws on the secondary side? |
wallys914 Timing your V8-914 / ATT: V8 Guys! Dec 20 2009, 05:31 PM
Cheapsnake Unless your advance curve is woefully flat I would... Dec 20 2009, 06:53 PM
messix hesitation when? tip in no load? part throttle cru... Dec 20 2009, 06:56 PM
TC 914-8
hesitation when? tip in no load? part throttle cr... Dec 20 2009, 10:24 PM
messix
hesitation when? tip in no load? part throttle c... Dec 21 2009, 12:44 AM
TC 914-8
[quote name='TC 914-8' post='1253294' date='... Dec 21 2009, 07:58 PM
computers4kids
hesitation when? tip in no load? part throttle c... Dec 21 2009, 09:30 AM
kg6dxn Get a vacuum gauge. connect to the intake, move di... Dec 20 2009, 09:37 PM
TC 914-8 What is this "Dizzy" you talk about ? So... Dec 21 2009, 07:38 PM
marks914 advance the timing until you have a ping, then bac... Dec 21 2009, 08:17 PM
wallys914 You guys think the NOS will blow the trans? Even i... Dec 21 2009, 09:13 PM
TC 914-8
You guys think the NOS will blow the trans? Even ... Dec 21 2009, 10:50 PM
marks914
You guys think the NOS will blow the trans? Even ... Dec 22 2009, 07:27 AM
Rand Sounds like you have a handle on it Wally. I'm... Dec 21 2009, 09:38 PM
JDJim
Sounds like you have a handle on it Wally. I... Dec 21 2009, 10:16 PM
wallys914 :mellow: All Valid Points! I will take the NO... Dec 22 2009, 03:01 PM
messix no2 builds big tourque as soon as it hits, think a... Dec 22 2009, 03:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th November 2026 - 03:49 PM |
