Amateur night - Cracked valve guide guide, oops |
fraggle00 |
Feb 22 2004, 03:11 PM
Newbie Group: Members Posts: 35 Joined: 27-September 03 From: Boise, ID Member No.: 1,202 |
OK, first lesson, if you get frustrated - STOP and get back to work later.
Now that I've learned that, what I can I do about this: I drilled my hole a little off-center for my intake valve guide removal ('75 2.0). Now I've got two problems 1) When I tapped the guide hole for my bolt, the threads bit into the sidewall of the head a little 2) Due to this, threads in the guide were weak and tore out 3) Got a little furstrated and tried an alternative method of banging out the guide (IMG:style_emoticons/default/headbang.gif) 4) Bad idea as it expanded a little and cracked the head down near the intake port. I quit right away at that point and found a better alternative method. I also scarred the valve guide hole a little. (IMG:http://home.mindspring.com/~frachel/headgoof-1.JPG) (IMG:http://home.mindspring.com/~frachel/headgoof-2.JPG) Question is: Is this repairable? I can't be the first one to have done something this dumb. Of course, the guide I knocked out went great, as well as the both exhaust guides. The '75 2.0 heads (for a very short time) used smaller diameter intake valve guides, so I probably could have it machined up to the next size, but I'm not sure what would happen down in the intake port. Experts??? What's the opinion out there? |
Dave_Darling |
Feb 24 2004, 01:42 AM
FAT Performance in Orange CA. Otto's in Venice. Headflow Masters in San Diego. They should all be able to cope with it. (I'm sure Steve from Otto's will chime in any minute now... <_< ) Don't know anyone in or near Boise.
Some of the OR/WA crowd may have suggestions that are closer. --DD |
Lo-Fi Version | Time is now: 3rd June 2024 - 01:19 AM |
