> Timing your V8-914 / ATT: V8 Guys!, any body got any good hints or suggestions?
wallys914
post Dec 20 2009, 05:31 PM
In life you don't get what you want, you get what you negoia
I set my motor up and everything is running great, but I can feel a like it has a lil hesitation.Without throwing a light on it, I cant get rid of it. I know that the distributor is off, just enough to effect perfection.
How have the V8 guys set up there 914's so that they can time them with easy?
Thanks,
messix
post Dec 22 2009, 03:47 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
no2 builds big tourque as soon as it hits, think about it this way... it's spraying at a constant rate along with fuel so your gonna get the big hit at lower rpm and and not so much at higher rpm.
i dare you to keep a clutch alive spraying it! (IMG:style_emoticons/default/happy11.gif)
i don't like the advance til it pings rule, and the time it by vac can have problems too. you can buy a degreed timming tape that sticks to the ballencer and make or buy an adjustable pointer and get it to tdc find a place that you can mount the pointer on the bottom side and then attach the tape so the poiter is at tdc. then you can put the car on stands or ramps and time it from the bottom [you'll still have to get up ad adjust the diz a little at a time.
best starting point on a average sbc is 36% at 3,000 rpm make sure its all in by then. then goof around with it from there.
wallys914   Timing your V8-914 / ATT: V8 Guys!   Dec 20 2009, 05:31 PM
Cheapsnake   Unless your advance curve is woefully flat I would...   Dec 20 2009, 06:53 PM
messix   hesitation when? tip in no load? part throttle cru...   Dec 20 2009, 06:56 PM
TC 914-8   hesitation when? tip in no load? part throttle cr...   Dec 20 2009, 10:24 PM
messix   hesitation when? tip in no load? part throttle c...   Dec 21 2009, 12:44 AM
TC 914-8   [quote name='TC 914-8' post='1253294' date='...   Dec 21 2009, 07:58 PM
computers4kids   hesitation when? tip in no load? part throttle c...   Dec 21 2009, 09:30 AM
kg6dxn   Get a vacuum gauge. connect to the intake, move di...   Dec 20 2009, 09:37 PM
wallys914   Thanks guys I will take a look at the fuel deliver...   Dec 21 2009, 06:39 PM
messix   Thanks guys I will take a look at the fuel delive...   Dec 21 2009, 07:04 PM
TC 914-8   What is this "Dizzy" you talk about ? So...   Dec 21 2009, 07:38 PM
marks914   advance the timing until you have a ping, then bac...   Dec 21 2009, 08:17 PM
wallys914   You guys think the NOS will blow the trans? Even i...   Dec 21 2009, 09:13 PM
TC 914-8   You guys think the NOS will blow the trans? Even ...   Dec 21 2009, 10:50 PM
marks914   You guys think the NOS will blow the trans? Even ...   Dec 22 2009, 07:27 AM
Rand   Sounds like you have a handle on it Wally. I'm...   Dec 21 2009, 09:38 PM
JDJim   Sounds like you have a handle on it Wally. I...   Dec 21 2009, 10:16 PM
wallys914   :mellow: All Valid Points! I will take the NO...   Dec 22 2009, 03:01 PM
messix   no2 builds big tourque as soon as it hits, think a...   Dec 22 2009, 03:47 PM
- Lo-Fi Version Time is now: 8th November 2026 - 03:49 PM
