| jsaum |
Dec 28 2009, 01:14 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
Anyone have advice on the best way to get the reservoir tubes and grommets into to the master cylinder? I couldn't get them to slip in with the grommets in the master cylinder so I tried pushing them on the metal tubes and then pressing them in neither way is working. I have every thing else in place.
| Cap'n Krusty |
Dec 29 2009, 09:50 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
"Pull the lines from the reservoir"? THAT sounds like the hardest way of all. Install the grommets and the washers, lube them with brake fluid, install the m/c, and pull the tubes in with a pair of needle nose vise grips and a sturdy hook tool. Sure it's hard, but so is life. Suck it up, folks. The Cap'n
jsaum Master cylinder Dec 28 2009, 01:14 AM
ArtechnikA
Anyone have advice on the best way to get the res... Dec 28 2009, 05:09 AM
GeorgeRud Rich's way is by far the best way, but if you ... Dec 28 2009, 06:50 AM
DBCooper There are aftermarket M/C's that I swear won... Dec 28 2009, 07:31 AM
jsaum
There are aftermarket M/C's that I swear won... Dec 28 2009, 10:39 AM
SLITS The aftermarket one is the Euro Parts one. They d... Dec 28 2009, 12:04 PM
SUNAB914 I used two lockjaw pliers to pull down on the line... Dec 29 2009, 08:55 AM
jsaum
"Pull the lines from the reservoir"? T... Dec 29 2009, 01:06 PM
RiqueMar I'll be noting this topic in a few days. I was... Dec 30 2009, 12:41 AM
greenie
"Pull the lines from the reservoir"? ... Dec 30 2009, 07:54 PM
ppeters914 This thread started about reinstalling the reservo... Dec 31 2009, 11:21 AM
ppeters914 Ack! Never mind. Found Pelican Parts tech arti... Dec 31 2009, 11:33 AM
ArtechnikA
I get that you need to get slack in the reservoir... Dec 31 2009, 01:00 PM
jsaum
[quote name='jsaum' post='1256169' date='Dec 29 2... Dec 31 2009, 12:51 PM
rfuerst911sc Here's how I did it. Loosen the clamp that hol... Dec 30 2009, 04:32 AM
etcmss I did it your first way and struggled and was succ... Dec 30 2009, 06:16 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th August 2026 - 04:33 AM |
