keith |
Newbie ![]() Group: Members Posts: 15 Joined: 1-March 03 From: Beavercreek, OR Member No.: 374 ![]() |
Shitfuckdammit. Ran so - so up until Saturday morning before JP's meet.
Here's the car 74 2.0 I would guess around 100k The car very original - the brake lines (which I replaced) and the shocks (which I have not) had a 1973 date on them. I don't believe the engine or any of the major components have been changed since it left the factory. Here what I have done: Replaced all vacuum lines Plugs, wires, points fuel/air filters, temp sensor II, alt, voltage regulator, battery, cap and rotor and points. Valve adjustment done about 500 miles ago. Problem: Hard to start. Kind of acts like it's got carbs when cold. After starting it will idle at 700 rpm and threated to die. For the first couple minites you can hold a steady RPM with the throttle, say 1200 to 1800 and higher if you want. After a couple of minutes it stumbles around this range. You just cant hold a steady RPM below 2000. Engine will rev freely past this point and while driving seems to run well. I've read about adusting the dwell then the timing in the manual. Do they even make a dwell meter anymore?? Any ideas welcome. Or free (IMG:style_emoticons/default/beer.gif) and pizza and use of my lift for anyone who can help. TIA Keith |
Mike D. |
OK, It runs now, and pretty good too! ![]() ![]() ![]() Group: Members Posts: 1,455 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None ![]() ![]() |
Sense your running the points and condenser, Check the points plate inside the dist. and make sure the ground strap is in good shape. If not you should replace the points plate and at that point I'd just get a compufire ignition and throw out the points and condenser.
You should also check the trigger points. This is the part in the base of the distributer withthe plug on it. Make sure it is not too worn. This tells the computer when to fire the injecters. Have you tried adjusting the nob on the top of the computer while the engine is idling? This adjusts the richness, but only at idle Just a few things to look at in addition to the Aux. Air valve mentioned above Have Fun Mike D. |
Lo-Fi Version | Time is now: 17th July 2025 - 04:48 AM |
