keith |
Newbie ![]() Group: Members Posts: 15 Joined: 1-March 03 From: Beavercreek, OR Member No.: 374 ![]() |
Shitfuckdammit. Ran so - so up until Saturday morning before JP's meet.
Here's the car 74 2.0 I would guess around 100k The car very original - the brake lines (which I replaced) and the shocks (which I have not) had a 1973 date on them. I don't believe the engine or any of the major components have been changed since it left the factory. Here what I have done: Replaced all vacuum lines Plugs, wires, points fuel/air filters, temp sensor II, alt, voltage regulator, battery, cap and rotor and points. Valve adjustment done about 500 miles ago. Problem: Hard to start. Kind of acts like it's got carbs when cold. After starting it will idle at 700 rpm and threated to die. For the first couple minites you can hold a steady RPM with the throttle, say 1200 to 1800 and higher if you want. After a couple of minutes it stumbles around this range. You just cant hold a steady RPM below 2000. Engine will rev freely past this point and while driving seems to run well. I've read about adusting the dwell then the timing in the manual. Do they even make a dwell meter anymore?? Any ideas welcome. Or free (IMG:style_emoticons/default/beer.gif) and pizza and use of my lift for anyone who can help. TIA Keith |
mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
They make dwell gauges, check the dwell. Check the timing too.
Make sure you test it correctly for your engine, there are probably vacuum lines you need to disconnect on the distributor. That makes a huge difference. |
Lo-Fi Version | Time is now: 17th July 2025 - 04:28 AM |
