| jsaum |
Dec 28 2009, 01:14 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
Anyone have advice on the best way to get the reservoir tubes and grommets into to the master cylinder? I couldn't get them to slip in with the grommets in the master cylinder so I tried pushing them on the metal tubes and then pressing them in neither way is working. I have every thing else in place.
| rfuerst911sc |
Dec 30 2009, 04:32 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
Here's how I did it. Loosen the clamp that hold the reservoir to the bracket. You can now push both brake lines down with the reservoir attached. With the steering rack cover removed push the lines down about a foot or so. Now the lines are out in the open where you have leverage. With the master cylinder in your hand pop each line in, very easy because you have leverage. Then slide the lines up until the master cylinder is in place. Install master cylinder and then put reservoir in place and tighten clamp. This whole process took me about 10 minutes. More than one way to skin a cat (IMG:style_emoticons/default/biggrin.gif) .
jsaum Master cylinder Dec 28 2009, 01:14 AM
ArtechnikA
Anyone have advice on the best way to get the res... Dec 28 2009, 05:09 AM
GeorgeRud Rich's way is by far the best way, but if you ... Dec 28 2009, 06:50 AM
DBCooper There are aftermarket M/C's that I swear won... Dec 28 2009, 07:31 AM
jsaum
There are aftermarket M/C's that I swear won... Dec 28 2009, 10:39 AM
SLITS The aftermarket one is the Euro Parts one. They d... Dec 28 2009, 12:04 PM
SUNAB914 I used two lockjaw pliers to pull down on the line... Dec 29 2009, 08:55 AM
Cap'n Krusty "Pull the lines from the reservoir"? TH... Dec 29 2009, 09:50 AM
jsaum
"Pull the lines from the reservoir"? T... Dec 29 2009, 01:06 PM
RiqueMar I'll be noting this topic in a few days. I was... Dec 30 2009, 12:41 AM
greenie
"Pull the lines from the reservoir"? ... Dec 30 2009, 07:54 PM
ppeters914 This thread started about reinstalling the reservo... Dec 31 2009, 11:21 AM
ppeters914 Ack! Never mind. Found Pelican Parts tech arti... Dec 31 2009, 11:33 AM
ArtechnikA
I get that you need to get slack in the reservoir... Dec 31 2009, 01:00 PM
jsaum
[quote name='jsaum' post='1256169' date='Dec 29 2... Dec 31 2009, 12:51 PM
etcmss I did it your first way and struggled and was succ... Dec 30 2009, 06:16 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th August 2026 - 04:35 AM |
