neilca |
Member ![]() ![]() Group: Members Posts: 98 Joined: 26-July 05 From: Marietta, GA Member No.: 4,474 ![]() |
I am setting up an EP 914-6 for SCCA regionals. I have 22mm front torsion bars and 350# springs in the rear. How low can I set the ride height? I have found the bolts that hold in the front sub frame to be the lowest point of the car and I can adjust the bars till it hits the ground. The rear I use the jack points on the back corners of the tub. I can lower these down to 2" off the ground. I have a set of the 23mm front bars also and can get heavier rear springs if needed. Any suggestions? I am runing cantilevered slicks from Goodyear. I will be running tracks like Road Atlanta, Barber, Roebling and CMP. How low can I go? Thanks, neilca. |
neilca |
![]() ![]() Here are some shots of the rear. I have had to add about 3/8 inch of spacers on the outboard adjuster to get the chamber out. I do need to add a bump stop to the shock so the arm will not hit the chassis. The shock has about 2 inches of travel left in this picture and the tub is about 3 inches off the floor. |
Lo-Fi Version | Time is now: 17th June 2024 - 02:58 AM |
