Rear Fender, Remove and replace |
watsonrx13 |
Feb 11 2004, 06:17 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
I've got the burnt 914 that needs the left rear fender removed and replaced. I have a parts car that has a good fender. I also want to replace the sail panel. How should I remove the fender? However you recommend, I'll use the exact same method for removing the parts car item. Once I remove the fender, I'll need to replace the door striker and some inner engine compartment sheet metal. Please be very specific and provide pics if possible. Thanks again for all of your help.
Attached image(s) |
watsonrx13 |
Feb 24 2004, 09:13 PM
Thanks for clearing that up Joe, from now on I'll refer to the bad repairs as the PPO (pre-previous owner - haha).
Rick, I'm trying to remove this fender as if I will use it again, it'll be good practice when I remove the fender from the donor car. Any recommendations for 'gracefully' removing the fender from the air tube? Also, what is the purpose of this air tube, anyway? |
Lo-Fi Version | Time is now: 29th May 2024 - 06:01 AM |
