EP 914-6 How low can I go? |
neilca |
Dec 31 2009, 11:35 AM
Member Group: Members Posts: 98 Joined: 26-July 05 From: Marietta, GA Member No.: 4,474 |
I am setting up an EP 914-6 for SCCA regionals. I have 22mm front torsion bars and 350# springs in the rear. How low can I set the ride height? I have found the bolts that hold in the front sub frame to be the lowest point of the car and I can adjust the bars till it hits the ground. The rear I use the jack points on the back corners of the tub. I can lower these down to 2" off the ground. I have a set of the 23mm front bars also and can get heavier rear springs if needed. Any suggestions? I am runing cantilevered slicks from Goodyear. I will be running tracks like Road Atlanta, Barber, Roebling and CMP. How low can I go? Thanks, neilca. |
ChrisFoley |
Jan 2 2010, 03:45 PM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Kind of hard to call that an EP car with the amount of original chassis metal missing. (IMG:style_emoticons/default/wink.gif)
Raising the rear pickups would solve multiple problems: Shock travel would increase; Trailing arm would have more clearance to the underside of the chassis; Less spacers needed to get desired camber; Lower rear roll center. |
Lo-Fi Version | Time is now: 17th June 2024 - 03:36 AM |
