| Jake Raby |
Oct 1 2009, 11:17 AM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
This is a sneak peek of the new cable linkage system that we have been working to complete for quite a while now.. Available (SOON!) for carburetors or our "Extrudabody" EFI throttle bodies.
These pics are of the first fitment of the new arrangement onto a pair of EMPI HPMX carbs on our display fixture. There are several changes necessary, but for a first mock up and fitment the system worked better than we'd imagine. The final kit will have all anodized parts, full hardware and etc included along with an installation DVD produced by yours truly. There have been efforts by others to complete a system like this,(some with great results) but to date nothing has been universally applicable or commercially available using this method of actuation and synchronization. There has also not been an attempt made to replace the OEM throttle cable all the way to the throttle pedal. The difference in this system is that the permanently lubricated sheathed cables will replace the ENTIRE throttle cable arrangement all the way to the pedal. This will be accomplished with a system thats comprised of one primary cable from the pedal to an intermediate link housing that will tie both cables together. The high quality, multi-role intermediate link will also have the adjustment and return spring for the arrangement in a combined unit. The intermediate link will reside above the transaxle and will triple as a quick disconnection point should the service of the engine/ carbs need to be carried out. This intermediate link is one bad ass, yet VERY SIMPLE part! The secondary cable couples to the primary cable via the intermediate link then travels around a billet cam on the "lead" carburetor/ throttle body. This cable then continues through another sheathed cable to the "slave" throttle body/ Carburetor. The benefits of the cable system are numerous.. I personally like the lightweight yet very robust construction coupled to the fact that it omits the factory throttle cable and replaces it all with new much stronger parts. It's also easy to custom tailor pedal feel and throttle actuation with adjustments made to the cams and cable tensions. I have been "over" Hex bar linkage systems and their inherent issues for years.. Bellcrank systems have proven to be expensive and can be problematic with engines that have greater expansion levels as their synchronization is effected as the engine "grows". With this system is doesn't matter how much the engine expands the cables retain their tension. This is the smoothest and most accurate means of carburetor actuation I have experienced to date. Here are some features: -Universally applicable for all Weber IDF/ EMPI HPMX and Dellorto DRLA applications for the Type 1, Type 4 or Porsche 356 engine!! The same kit can fit all these different engines! The same kit can also fir a Type 3 or Type 4 engine using these carburetors with the stock pancake cooling system. -With very slight changes this same kit can actuate a set of 48 IDAs on any of the above engines as well. -High quality billet throttle cams allow for easy adjustment of the system for various pedal arrangements -The entire stock throttle cable is removed and replaced with the "accu-link" components -The intermediate link allows for ease of adjustment, a quick disconnection point, coupling of the primary and secondary cables and a redundant throttle return spring all in one self contained, snap together housing. - The sheathed cables are adjustable in 7 different locations for ease of tuning the system to the vehicle, driver and carburetors. -Engine width and expansion will not alter carburetor/ throttle body actuation or synchronization at all. - Very light carb return springs are able to be used due to the ease of actuation and the slippery sheathed cables. This allows for a nice pedal feel without giving up snappy throttle action -Carburetor throttle shaft bearings/ bushings will see reduced loads and will live longer. - No mechanical parts to wear out like ball sockets and heim joints/ spherical bearings. When the cables begin to stretch the adjustment can be made to them in 7 different places throught the arrangement. Spare cables can be sold for pennies to keep in the glove box.. - No heavy mechanical linkages to attach to the throttle shafts and transmit harmonics to the throttle shafts, thus chattering the accelerator pumps making them dribble fuel down the intakes.. This is a tuning issue that many people fight and do not even realize it. - Its different! As different as a DTM cooling system or a big bore Type 4! -Its also going to be very cost effective with all parts (except the throttle intermediate link) made in the USA including the cables, billet throttle cams and etc. The throttle intermediate link is made in Germany and has been proven in the 24 hours of Le Man as recently as this past June :-) And as of today the Patent pending processes have been initiated! This post has been edited by Jake Raby: Oct 1 2009, 11:19 AM |
| DBCooper |
Jan 3 2010, 07:48 AM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
That linkage is exactly what's been on the BMW R-series oilhead boxers since at least 1993, so that may be where Porsche got the idea. It's good, but don't get your hopes too high. The cables do stretch and wear in, especially in the beginning when they're new, so they aren't totally hands-off. They'd eliminate it if they could, but BMW keeps TB syncing in the maintenance schedules for the life of their bikes.
I used the older BMW R-series airhead cables on a dune buggy in the 70's, copying a setup I'd seen on a car at Pismo. Those are a little different, a "Y" cable with a length adjuster in one leg of the "Y" for sync. Cheap, simple and worked great, but again it wasn't perfect. By the way, there's a sync tool the BMW motorcycle guys use that's really cool, a lot better than any of the Unisyn or snail type flow gauges. It's an electronic vacuum comparison gauge called the TWIN MAX (link). Since it's electronic you can even dial the signal buffering up or down, to average and dampen the pulses and steady the needle. Quick, easy, and extremely accurate, kind of like electronic mercury sticks. More expensive than the Unisyn, but it really does the job. (IMG:http://www.adventuremotogear.com/images/Twinmax2.jpg) For dual IDF"s or DRLA's or four-cylinder motorcycle engines they say you just sync any two barrels, then use one as the standard and sync the remaining two to the first. I haven't tried it that way, but it works so well on the boxer twins that I don't doubt it a bit. |
Jake Raby New Carb linkage for /4 engines- RAT "Accu-Link" Oct 1 2009, 11:17 AM
ghuff That stainless braid looks so badass and gangster ... Oct 1 2009, 11:42 AM
FourBlades I want one. :trophy: :trophy: :trophy:
I am ... Oct 1 2009, 11:46 AM
SUNAB914 Any ideas on cost yet? I would seriously consider ... Oct 1 2009, 11:47 AM
Jake Raby These are non compressable sheaths.. The cable is ... Oct 1 2009, 11:48 AM
ghuff
These are non compressable sheaths.. The cable is... Oct 1 2009, 11:58 AM
URY914 Seems way too simple. Oct 1 2009, 11:56 AM
Jake Raby
The ECU is in my 912E now... I need to download ... Oct 1 2009, 12:10 PM
9146986 Great work Jake! This is long overdue. Oct 1 2009, 01:22 PM
tat2dphreak this looks great, Jake! be sure and let us kno... Oct 1 2009, 01:44 PM
jmill I like it. Beats the heck out of anything I'v... Oct 1 2009, 02:13 PM
Jake Raby Throttle idle stop is on the opposite side of the ... Oct 1 2009, 02:17 PM
underthetire looks like my dirtbike set-up ! cool ! Oct 1 2009, 03:12 PM
flipb I might wait to convert my 2.0 from single Weber p... Oct 1 2009, 03:14 PM
Jake Raby Can **I** demolish the single carb??
LOL.. I got ... Oct 1 2009, 03:24 PM
tomeric914 Why must you continue to taunt me with products I ... Oct 1 2009, 03:34 PM
Jake Raby
Why must you continue to taunt me with products I... Oct 1 2009, 03:42 PM
jhadler Could this work on other throttle body setups as w... Oct 1 2009, 03:48 PM
Jake Raby With mods I am sure it could...
The TWMs have real... Oct 1 2009, 03:52 PM
jhadler
The TWMs have rea... Oct 1 2009, 04:09 PM
BarberDave :trophy:
Jake :
We expect nothin... Oct 1 2009, 04:06 PM
Jake Raby
:trophy:
Jake :
We expect nothi... Oct 1 2009, 04:21 PM
degreeoff the only issue I see is where the main joins the c... Oct 1 2009, 04:42 PM
Jake Raby Actually thats only ONE cable! It has a barrel... Oct 1 2009, 05:01 PM
Vacca Rabite Jake this is really cool. Now that I have seen it... Oct 1 2009, 07:07 PM
Jake Raby Yep!!!
A few people have made their ow... Oct 1 2009, 08:14 PM
ghuff
Yep!!!
A few people have made their o... Oct 1 2009, 11:28 PM
Mark Henry
Yep!!!
A few people have made their ... Oct 2 2009, 03:58 AM
ghuff
[quote name='ghuff' post='1220918' date='Oct 2 20... Oct 2 2009, 11:32 PM
scotty b Long anough for oh.... say...... a bus with a 6 in... Oct 1 2009, 08:22 PM
Jake Raby This will fit a six also... Oct 1 2009, 08:51 PM
jd74914
This is a sneak peek of the new cable linkage sys... Oct 1 2009, 08:59 PM
Jake Raby We've been working on several projects with ex... Oct 1 2009, 09:00 PM
jd74914 That's awesome! Thanks for the heads up. :... Oct 1 2009, 09:01 PM
STP This looks very cool.
I'm tired of my Hexbar... Oct 1 2009, 09:55 PM
Jake Raby it's already working.. Just gotta optimize it. Oct 1 2009, 10:05 PM
RJMII That is a slick looking setup! I've got a ... Oct 1 2009, 10:12 PM
Sleepin Wow! Everything seems so simple once you actua... Oct 1 2009, 10:53 PM
Rod The best ideas are always the simplest. Go Jake. ... Oct 2 2009, 05:36 AM
7275914911 Jake,
Will this work on carbs that one pulls/push... Oct 2 2009, 06:37 AM
Jake Raby For this to work both carbs will have to rotate in... Oct 2 2009, 04:30 PM
RJMII how simple would it be to make it so they didn... Oct 2 2009, 04:51 PM
Jake Raby Anything is possible..A version like this would ha... Oct 2 2009, 05:01 PM
HAM Inc I freakin" can't wait to ditch the hex ba... Oct 2 2009, 05:23 PM
McMark This is similar to what I've been carrying aro... Oct 2 2009, 07:33 PM
Jake Raby I now have a tentative price... 159.00 per kit..
T... Oct 2 2009, 08:18 PM
flipb Do you also anticipate selling carb kits that incl... Oct 2 2009, 08:22 PM
Jake Raby
Do you also anticipate selling carb kits that inc... Oct 2 2009, 08:38 PM
URY914 Let me be the first to point out that this new sys... Oct 2 2009, 08:49 PM
tat2dphreak I only wish I hadn't just bought a new linkage... Oct 2 2009, 08:51 PM
Jake Raby It is light!!Very light!
Otherwise Len... Oct 2 2009, 09:03 PM
brer looking good. Oct 2 2009, 11:53 PM
craig downs I like it. I was thinking on making a cable linkag... Oct 3 2009, 12:29 AM
FourBlades I am definitely in for 1 and maybe for 2 if they w... Oct 3 2009, 08:00 AM
ConeDodger If you want to sell volume in this Jake, trademark... Oct 3 2009, 10:08 AM
Jake Raby Bugpack is my choice for the re-seller in the T1 w... Oct 3 2009, 11:22 AM
biosurfer1 Any update on this? I'm ready to "adjust... Jan 2 2010, 06:29 PM
McMark Jake's gone til Monday, then he'll be catc... Jan 2 2010, 07:05 PM
ConeDodger
Killin' Wild Boa... Jan 3 2010, 12:33 AM
turnaround89 Spring would be perfect, i really want one of thes... Jan 2 2010, 11:04 PM
bandjoey With this low friction material and life turn it i... Jan 3 2010, 12:50 AM
SGB I'm ready too.
Did the roller cam setup ever ... Jan 3 2010, 01:03 AM
JmuRiz
I'm ready too.
Did the roller cam setup ever... Jan 5 2010, 10:52 AM
RobW Super Cool! :cheer: Jan 3 2010, 08:15 AM
jmill They do sell pre-stretched cable. They've bee... Jan 3 2010, 07:31 PM
scotty b How much load do you guys plan on putting on this ... Jan 3 2010, 07:53 PM
DBCooper I don't know. They've been making BMW box... Jan 3 2010, 10:46 PM
turnaround89 it may not be perfect, but i think it will work a ... Jan 4 2010, 01:02 AM
Joe Ricard Hex bar was designed by a retard. Jan 5 2010, 12:11 AM
geniusanthony Worse yet is the chinese company that "copied... Jan 5 2010, 12:52 AM
crash914 hmmm.. got a 94 oil head. got a twin max. I KNOW... Jan 5 2010, 04:00 AM
Jake Raby One of the biggest parts of this development has b... Jan 5 2010, 10:07 AM
Jake Raby Roller development is done for the 2270, I have be... Jan 5 2010, 01:40 PM
JmuRiz Excellent!
Does it still have the small carbs ... Jan 5 2010, 02:38 PM
Jake Raby Just 40mm Dells.. Thats all it has needed and I kn... Jan 5 2010, 07:00 PM
turnaround89 Glad to hear the testing is going well, can't ... Jan 5 2010, 07:41 PM
Jake Raby Based on all the initial interest we have had I ex... Jan 5 2010, 07:49 PM
r_towle Consider making it totally hidden. That would cert... Jan 5 2010, 08:00 PM
Jake Raby
Consider making it totally hidden. That would cer... Jan 6 2010, 07:52 PM
eric914
Yep!!!
A few people have made their o... Jan 6 2010, 03:22 PM
biosurfer1 Well after working on my stupid crossbar linkage f... Mar 22 2010, 11:12 AM
HAM Inc I found with one CB hex bar that I set-up that the... Mar 22 2010, 11:17 AM
tat2dphreak
I found with one CB hex bar that I set-up that th... Mar 22 2010, 11:33 AM
jeffdon I had an idea for making up a cable linkage (see d... Mar 23 2010, 08:55 AM
Van
I had an idea for making up a cable linkage (see ... Mar 23 2010, 12:26 PM
r_towle
I had an idea for making up a cable linkage (see ... Mar 23 2010, 06:55 PM
Vacca Rabite Wish these were on the market now. I am redoing m... Mar 23 2010, 10:10 AM
biosurfer1 Me too Zach...I just hate screwing with the hex ba... Mar 23 2010, 11:44 AM
tat2dphreak
:agree: the CB performance setup is a comparable ... Mar 23 2010, 11:49 AM
jeffdon
:agree: the CB performance setup is a comparable... Mar 23 2010, 11:53 AM
biosurfer1 I've looked at the bellcrank setup and it seem... Mar 23 2010, 11:57 AM
jeffdon
I've looked at the bellcrank setup and it see... Mar 23 2010, 12:08 PM
Jake Raby I had hoped to have this on the market now.. But t... Mar 23 2010, 01:13 PM
Cevan While I'm waiting for engine parts for my buil... Mar 23 2010, 01:30 PM
Van Chris, you seem to be a master mechanic and a mast... Mar 23 2010, 02:38 PM
jeffdon
Chris, you seem to be a master mechanic and a mas... Mar 23 2010, 02:41 PM
jeffdon Here is a pic of the bellcrank. Sorry about the q... Mar 23 2010, 02:52 PM
Van
By the way, what shade of silver is your car?
... Mar 23 2010, 03:39 PM
Vacca Rabite Jake, if you need a test vehicle, my car is ready ... Mar 23 2010, 06:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th November 2026 - 06:03 AM |
