EJP914 |
Member ![]() ![]() Group: Members Posts: 273 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 ![]() |
Has anyone had to cut down the rubber top holders in the rear trunk so it will close with the top in it? They are new and are hitting on the cross brace inside the trunk lid when the top is stowed. It looks like the rubber holders should be inside - toward the front of the brace - for the lid to close. Guess I could move the trunk lid to the rear a bit, but it will overhang the taillights. Is that normal? Moving the lid rearward will also increase the gap between the trunk lid and engine cover. Any idea on how wide that gap should be?
Thanks in advance for the help. |
nomore9one4 |
Member of the Eastcoast Thread Killers Club ![]() ![]() ![]() ![]() Group: Members Posts: 2,666 Joined: 26-December 02 From: Pittsburgh,Pa.15237 Member No.: 14 Region Association: None ![]() |
Ed, Make sure you have the top in the correct way. The targa "flap" latches should go into the strut area of the trunk
FAT DANNY |
Member ![]() ![]() Group: Members Posts: 75 Joined: 13-December 09 From: Los Angeles Member No.: 11,121 Region Association: Southern California ![]() |
Ed, Make sure you have the top in the correct way. The targa "flap" latches should go into the strut area of the trunk Thanks, that helped me too! (IMG:style_emoticons/default/biggrin.gif) I have the same issue. The only difference is that my trunk lid is not tight so I can move it 1/2 inch in any direction, which helps when latching, but looks wrong. |
Lo-Fi Version | Time is now: 9th July 2025 - 03:14 PM |
