> Is my case shot?
Cevan
post Jan 4 2010, 07:47 PM
So after I had removed all the head studs from the case, I noticed a couple had come out real hard, as if something was wrong with the threads. After cleaning the threads of the stud, I couldn't thread them back in the two suspect holes.
I got a 12mmx 1.5tap and chased those holes. Now, the head studs go right in and they wiggle!! Even after I bottom them out, they can be moved relative to where they exit the case.
Is the case shot? What did I do wrong?
Katmanken
post Jan 4 2010, 10:36 PM
You haven't seen me if anybody asks...
While you were cleaning the studs, did you notice aluminum trapped in in the threads on the studs that came out hard?
If so, that might explain your loose fitting stud/hole combo...
Inserts are the only way to fix that, and don't use a hand drill. They need to be installed with precision machinery to ensure the studs don't cock. By precison, the case has to be held flat on the machined surface and either a drill or a mill comes in perpendicular to the machined surface to ensure the inserts are oriented correctly.
Cevan   Is my case shot?   Jan 4 2010, 07:47 PM
bam914   They should thread in tight like that. The only t...   Jan 4 2010, 08:07 PM
Van   They should thread in tight like that. The only ...   Jan 5 2010, 08:06 AM
Cevan   They should thread in tight like that. The only...   Jan 5 2010, 09:12 AM
Cap'n Krusty   A standard tap, the one everybody has, is NOT mean...   Jan 4 2010, 08:51 PM
Cevan   Seeing as I screwed up only one of the case halves...   Jan 4 2010, 09:42 PM
bdstone914   Seeing as I screwed up only one of the case halve...   Jan 4 2010, 10:05 PM
kwales   While you were cleaning the studs, did you notice ...   Jan 4 2010, 10:36 PM
Mark Henry   And NO to using two different case halves. They ar...   Jan 4 2010, 10:41 PM
sww914   Take it to a machine shop and have them fix it. It...   Jan 4 2010, 10:58 PM
Cevan   Thanks for the replies. Looking back on what I di...   Jan 5 2010, 07:10 AM
Rand   My bad - I was thinking exhaust studs. Disregard ...   Jan 5 2010, 09:45 AM
Jake Raby   You should have used a thread chaser, not a tap. T...   Jan 5 2010, 09:55 AM
Cevan   You should have used a thread chaser, not a tap. ...   Jan 5 2010, 01:50 PM
brp986s   Definitely have a shop do it, and a good one at th...   Jan 5 2010, 03:40 PM
r_towle   You should have used a thread chaser, not a tap....   Jan 5 2010, 04:52 PM
underthetire   :agree: Just make sure your table is square to th...   Jan 5 2010, 04:54 PM
kwales   Most drill presses aren't an option.... That ...   Jan 5 2010, 06:27 PM
r_towle   A drill press with a large top bolted in place wil...   Jan 5 2010, 08:05 PM
Dr Evil   Thanks for posting this mistake. I have done simil...   Jan 5 2010, 08:14 PM
jmill   While you might be tempted to spend all your mone...   Jan 5 2010, 09:30 PM
Cevan   Is a thread locker required when reinstalling the ...   Jan 6 2010, 09:15 AM
underthetire   http://www.mcmaster.com/#inch/metric-threa...inser...   Jan 6 2010, 11:24 AM
Vacca Rabite   Before you go and spend $100 on the TimeCert ...   Jan 6 2010, 02:12 PM
Cevan   Before you go and spend $100 on the TimeCert...   Jan 6 2010, 02:30 PM
underthetire   Before you go and spend $100 on the TimeCer...   Jan 6 2010, 02:43 PM
Cevan   I'm getting a headache. :D I think I'll ...   Jan 6 2010, 02:47 PM
ME733   :popcorn: Just out of curosity, why did you remov...   Jan 6 2010, 06:39 PM
r_towle   Brockton, Dedham and Newburyport. There are other...   Jan 6 2010, 08:52 PM
- Lo-Fi Version Time is now: 3rd July 2025 - 08:05 PM
