> Is my case shot?
Cevan
post Jan 4 2010, 07:47 PM
So after I had removed all the head studs from the case, I noticed a couple had come out real hard, as if something was wrong with the threads. After cleaning the threads of the stud, I couldn't thread them back in the two suspect holes.
I got a 12mmx 1.5tap and chased those holes. Now, the head studs go right in and they wiggle!! Even after I bottom them out, they can be moved relative to where they exit the case.
Is the case shot? What did I do wrong?
Mark Henry
post Jan 4 2010, 10:41 PM
that's what I do!
And NO to using two different case halves. They are a matched set.
Cevan   Is my case shot?   Jan 4 2010, 07:47 PM
bam914   They should thread in tight like that. The only t...   Jan 4 2010, 08:07 PM
Van   They should thread in tight like that. The only ...   Jan 5 2010, 08:06 AM
Cevan   They should thread in tight like that. The only...   Jan 5 2010, 09:12 AM
Cap'n Krusty   A standard tap, the one everybody has, is NOT mean...   Jan 4 2010, 08:51 PM
Cevan   Seeing as I screwed up only one of the case halves...   Jan 4 2010, 09:42 PM
bdstone914   Seeing as I screwed up only one of the case halve...   Jan 4 2010, 10:05 PM
kwales   While you were cleaning the studs, did you notice ...   Jan 4 2010, 10:36 PM
Mark Henry   And NO to using two different case halves. They ar...   Jan 4 2010, 10:41 PM
sww914   Take it to a machine shop and have them fix it. It...   Jan 4 2010, 10:58 PM
Cevan   Thanks for the replies. Looking back on what I di...   Jan 5 2010, 07:10 AM
Rand   My bad - I was thinking exhaust studs. Disregard ...   Jan 5 2010, 09:45 AM
Jake Raby   You should have used a thread chaser, not a tap. T...   Jan 5 2010, 09:55 AM
Cevan   You should have used a thread chaser, not a tap. ...   Jan 5 2010, 01:50 PM
brp986s   Definitely have a shop do it, and a good one at th...   Jan 5 2010, 03:40 PM
r_towle   You should have used a thread chaser, not a tap....   Jan 5 2010, 04:52 PM
underthetire   :agree: Just make sure your table is square to th...   Jan 5 2010, 04:54 PM
kwales   Most drill presses aren't an option.... That ...   Jan 5 2010, 06:27 PM
r_towle   A drill press with a large top bolted in place wil...   Jan 5 2010, 08:05 PM
Dr Evil   Thanks for posting this mistake. I have done simil...   Jan 5 2010, 08:14 PM
jmill   While you might be tempted to spend all your mone...   Jan 5 2010, 09:30 PM
Cevan   Is a thread locker required when reinstalling the ...   Jan 6 2010, 09:15 AM
underthetire   http://www.mcmaster.com/#inch/metric-threa...inser...   Jan 6 2010, 11:24 AM
Vacca Rabite   Before you go and spend $100 on the TimeCert ...   Jan 6 2010, 02:12 PM
Cevan   Before you go and spend $100 on the TimeCert...   Jan 6 2010, 02:30 PM
underthetire   Before you go and spend $100 on the TimeCer...   Jan 6 2010, 02:43 PM
Cevan   I'm getting a headache. :D I think I'll ...   Jan 6 2010, 02:47 PM
ME733   :popcorn: Just out of curosity, why did you remov...   Jan 6 2010, 06:39 PM
r_towle   Brockton, Dedham and Newburyport. There are other...   Jan 6 2010, 08:52 PM
- Lo-Fi Version Time is now: 3rd July 2025 - 08:19 PM
