Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
So after I had removed all the head studs from the case, I noticed a couple had come out real hard, as if something was wrong with the threads. After cleaning the threads of the stud, I couldn't thread them back in the two suspect holes.
I got a 12mmx 1.5tap and chased those holes. Now, the head studs go right in and they wiggle!! Even after I bottom them out, they can be moved relative to where they exit the case. Is the case shot? What did I do wrong? |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
You should have used a thread chaser, not a tap. The chase has much shallower roots and doesn't create this issue.
Now that it has occurred you can drill the case 2mm over size and install a time-sert. Thats your best bet for something thats fairly easy to do and inexpensive. |
Cevan |
You should have used a thread chaser, not a tap. The chase has much shallower roots and doesn't create this issue. Now that it has occurred you can drill the case 2mm over size and install a time-sert. Thats your best bet for something thats fairly easy to do and inexpensive. I hope others learn from my mistake. I contacted my local Time Sert dealer and the kit plus the correct size inserts is a little over $100. Do I need to have a machine shop drill and tap the holes in order to keep everything square or is this something I can hand drill and tap? |
brp986s |
Member ![]() ![]() Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 ![]() |
Definitely have a shop do it, and a good one at that. I had a case messed up by some hack where the studs ended up pointing every which way like some bucktoothed hillbilly. The studs need to be square or it will confound your torque values. It would be a bummer to blow $100 on inserts then toss the case.
Lo-Fi Version | Time is now: 4th July 2025 - 03:01 AM |
