ljet gurus needed, help |
type11969 |
Jan 8 2010, 11:23 AM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
My '76 Westy running a 2.0 ljet camper special engine decided not to start the other day . . . right before I was planning on driving it up to the poconos for NYE weekend. Better in my garage than up there. I haven't had a whole lot of time to troubleshoot but this is what I have so far:
Fuel pressure is at 38-40psi when cranking Injectors get 12v with the ignition on An led inline with an injector connector flashes when cranking I smell fuel when I stick my nose in the tailpipe Timing light indicates that I have spark Grounding a plug also indicates that I have spark All of the above seem to indicate that it should still start considering it was running fine over thanksgiving weekend. Only thing I did between then and now was pull the windshield to take care of some rust/install a new seal. Some other things to mention It will fire, barely, when initially cranking . . . thought this might be the engine running off of only the cold start valve but the LED test seems to indicate that the injectors should be firing. If I pull a plug, stick my hand over the hole and crank my hand sure doesn't reek of gas . . . which seems to indicate that the injectors are not firing. Then again, I've never tried this before so I'm not sure how much my hand would smell of gas anyway. So maybe the injectors are not getting enough voltage to fire? But enough to trigger the LED? I am going to pull one rail to check the spray. Any other ideas? This is cross posted on thesamba so apologies for any repeat readers. Thanks, Chris |
ClayPerrine |
Jan 8 2010, 11:44 AM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Get some carb spray, and spray it into the intake. I usually disconnect the hose from the aux air regulator to the big air flow meter hose. Fill up the intake and try cranking it. If it fires, it is fuel delivery. If it doesn't, check the ignition.
Fuel delivery. Start with 4 clean jars the same size. Pull the injectors and put them in the jars. Crank it and see if the jars fill up the same amount. If not, then use a noid light to check each injector plug to verify the pulsing. You can also use a automotive stethoscope to verify that the injectors are actually clicking...... Oh..and take a fuel sample. Could be water in the gas. |
Sleepin |
Jan 8 2010, 11:53 AM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:33 PM |
