Rear Fender, Remove and replace |
watsonrx13 |
Feb 11 2004, 06:17 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
I've got the burnt 914 that needs the left rear fender removed and replaced. I have a parts car that has a good fender. I also want to replace the sail panel. How should I remove the fender? However you recommend, I'll use the exact same method for removing the parts car item. Once I remove the fender, I'll need to replace the door striker and some inner engine compartment sheet metal. Please be very specific and provide pics if possible. Thanks again for all of your help.
Attached image(s) |
Joe Ricard |
Feb 25 2004, 11:23 AM
I'm going out on a limb here but I think it is for the air coming into the car from the vents or heater to escape. Otherwise your ears would pop. unless the car is 30 years old and all the rubber has shrunk.
Lo-Fi Version | Time is now: 29th May 2024 - 04:26 AM |
