Front Bearing Progress, yes |
J P Stein |
Jan 11 2003, 04:37 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
In to have some lunch.
The fittment is going fairly well. Slop is NOT a problem....many fits are tighter than hell. My A arm shafts are prolly bigger than most at 1.421. The hardened sleeves (inner race) ID is 1.421, but as they are a bit out of round (not unusual with a thin sleeve) it makes fitting dicey.....once they are started on, you're committed. Let's just say they are never coming off in one peice. The same was true with the aft brg holder. Those are way out of round due the goodie welded to the side of em. That took some doing: |
Mueller |
Jan 11 2003, 08:48 PM
I knew I should have sampled more arms for that dimension (IMG:style_emoticons/default/sad.gif)
I'll have to spring for a couple of beers now for your extra work (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 08:01 PM |
