mtndawg |
Member ![]() ![]() Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None ![]() ![]() |
I've been looking for info on the AAR and most of the discussions have been about the AAR being stuck closed. I'm wondering if mine is letting too much air through at start up? I've got my 1.7L d-jet pretty close to where I want it. When it's warm I'm idling around 900ish. Vacuum lines are new and fuel pressure is perfect.
When the engine is cold and I start it up, it jumps to 2000 to 2300 rpm. When I take the hose off the AAR it's sucking a LOT of air. Restricting it with my thumb of course drops the idle. After about 3 minutes the valve is closing and the idle drops on it's own. There's also a little white smoke at start up. What do the experts think? |
mtndawg |
Shouldn't it start to idle around 1500 to 1800?
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,094 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Shouldn't it start to idle around 1500 to 1800? I don't know your idle spec. I can tell you this, the white smoke is not related. Wait until the idle drops and then put your finger over the hole. If the idle drops further it isn't closing completely. I suspect if your idle is wrong you need to set if but that doesn't involve the AAR. I see the Cap'n is reading this thread. HE IS AN EXPERT. If he posts, ignore mine. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 4th July 2025 - 03:32 AM |
