> TRANSMISSION REBUILD VIDEO THREAD, Input sought!
Dr Evil
post Jan 24 2010, 01:39 PM
Send me your transmission!
The video is getting closer to happening as Eric (cupomeat) and I just work on firming up a date in the near future. The video will cover the full tear down, inspection and rebuild of both side and tail shift (both /4 and /6) transmissions, but the video can not cover everything that I wish to. As such, I have taken the last 4 days in the middle of nowhere MN to start writing the notes that will accompany the video. The notes may be made available for free as well at a later time, but for now I need to make sure that they are as complete as I can make them. I have much of them done already, but I am still in the editing phase. If you have some info (factual or anecdotal) or experience with any of the topics, feel free to post them so I can either shoot them down or include them (IMG:style_emoticons/default/wink.gif)
Here is the outline so far:
Transmission rebuild video supplement:
Forward
– What the deal is
Chapter 1 – Do I need a rebuild?
What external things to inspect
*Engine mounts
*Trans mounts
*Bushings
*Cone screws
*Clutch cable adjustment and issues
-How to adjust cable
-Broken tube
How to adjust the shifter
Inspecting core tranny
*Input shaft and output flanges turn?
*Input shaft play?
*“it shifts fine on the floor”, Oh goody, big deal.
A word on reading used transmission oil
Chapter 2 – Do I need that?
Myths and musings
*Billet intermediate plate
*Through bolting the intermediate plate/case/tail cone
*Lubricants
-Dino vs Royal Purple vs Swepco
*Galvanic chart: Stainless hardware FACTS
-SS hardware will not prematurely corrode your case and why not
*Corrosion protection
-Original factory coating
-Options for aftermarket
Chapter 3 – Tweaking your gears and diff
Gear selection
*Considerations
*Engine dependent gearing
*Interpreting gearing
*Intended usage of the gear box
*Flipping gears
Limited slip differentials
*The main idea - what they do
*Torque biasing
*Friction biasing
Welded differentials
*Don't do it!
Chapter 4
– Troubleshooting, care, and feeding of your 901
Problem list
*Reverse gear grinds
*Pops out of gear
*Grinds
*Whining
*Clutch will not disengage – resurfaced flywheel usage?
*Clunk and shifts funny
*Pivot ball leak?
General maintenance
*Oil changing
Appendix
Torques and values
*Case nuts, 8x1.25
*Speedo retainer bolt
*Throwout bearing guide tubs nuts, 10x?
*Detente package retainer bolt, 14mm
*Pinion bolt
*Input shaft nut
Special tools list
ericread
post Jan 24 2010, 02:31 PM
The Viper Blue 914
Where are the step-by-step instructions of tearing down and re-assembling the tranny?
The inspection and myth stuff is sure to be helpful, but what I need is a refresher from when I crack the case to when I bolt it back together.
Eric
smontanaro
post Jan 24 2010, 02:46 PM
QUOTE(ericread @ Jan 24 2010, 02:31 PM) *
... I need is a refresher from when I crack the case to when I bolt it back together.
"Assembly is the reverse of disassembly." What more do you need? (IMG:style_emoticons/default/biggrin.gif)
Dr Evil   TRANSMISSION REBUILD VIDEO THREAD   Jan 24 2010, 01:39 PM
underthetire   Special tool list please.   Jan 24 2010, 01:48 PM
Gint   Special tool list please.Reasonable substitutes fo...   Jan 24 2010, 10:17 PM
Gint   Special tool list please.Reasonable substitutes fo...   Jan 25 2010, 02:06 PM
Dr Evil   [quote name='Gint' post='1265333' date='Jan 24 20...   Jan 25 2010, 02:12 PM
Dr Evil   Good idea! Added to the first post. I will inc...   Jan 24 2010, 02:03 PM
jmill   How about a section on selecting gear ratios for y...   Jan 24 2010, 02:14 PM
rick 918-S   Speciality tools as an option when purchasing a vi...   Jan 24 2010, 02:22 PM
ericread   Where are the step-by-step instructions of tearing...   Jan 24 2010, 02:31 PM
smontanaro   ... I need is a refresher from when I crack the ca...   Jan 24 2010, 02:46 PM
Dr Evil   Um, Eric, the video is intended to cover those thi...   Jan 24 2010, 09:22 PM
ericread   Um, Eric, the video is intended to cover those th...   Jan 25 2010, 09:11 AM
Dr Evil   I have the chapters 1 and 3 done for review. I wil...   Jan 24 2010, 09:28 PM
FourBlades   Maybe say a few words about converting tail shifte...   Jan 24 2010, 09:28 PM
Dr Evil   Maybe say a few words about converting tail shift...   Jan 24 2010, 09:38 PM
Dr Evil   Chapter 1 – “Do I even need a rebuild?” Wha...   Jan 24 2010, 09:34 PM
Dr Evil   [u]Chapter 3 – Tweaking your gears and diff [b]...   Jan 24 2010, 09:37 PM
detoxcowboy   Dr. Evil, Maybe something on using used parts...   Jan 24 2010, 09:46 PM
Dr Evil   That will be in the video :)   Jan 24 2010, 09:51 PM
detoxcowboy   Dr. Evil Anything about indexing the shift rod to...   Jan 24 2010, 10:30 PM
Dr Evil   Crap, I totally forgot to add the shift adjustment...   Jan 24 2010, 11:01 PM
computers4kids   I know your producing a DVD, but how about also cr...   Jan 25 2010, 09:44 AM
Dr Evil   I know you producing a DVD, but how about also cr...   Jan 25 2010, 02:14 PM
turboman808   I'll see if Eric has any idea about this. I ...   Jan 25 2010, 02:55 PM
Dr Evil   I'll see if Eric has any idea about this. I...   Jan 25 2010, 06:34 PM
charliew   Mike I'm sure you have also thought about the ...   Jan 25 2010, 10:10 AM
Dr Evil   Mike I'm sure you have also thought about the...   Jan 25 2010, 02:09 PM
kwales   Evil, Hows about a little dialoge on dos and don...   Jan 25 2010, 11:52 AM
Dr Evil   Evil, Hows about a little dialoge on dos and don...   Jan 25 2010, 02:10 PM
RoadGlue   Hey Mike, this is awesome! Let me know if I ca...   Jan 25 2010, 02:01 PM
bandjoey   It'd only take about a weeks worth of producti...   Jan 26 2010, 05:02 PM
Dr Evil   I hope it is not just informative, but also entert...   Jan 26 2010, 05:35 PM
Dr Evil   OK, Folks! The date for shooting this has been...   Feb 4 2010, 11:13 AM
- Lo-Fi Version Time is now: 1st July 2025 - 10:35 PM
