| ChrisFoley |
Jan 21 2010, 03:48 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,030 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
This prototype will be ready for installation in my street car in a few days.
(IMG:http://www.tangerineracing.com/images/EnginePics/TangerineEngineCoolingSystemPrototype01.jpg) (IMG:http://www.tangerineracing.com/images/EnginePics/TangerineEngineCoolingSystemPrototype02.jpg) Update: 02/18/10 Pre-production discount price of $1359 in effect through 03/07/10 Paypal accepted at my website. Horizontal Cooling Fan Conversion |
| Mr.242 |
Jan 21 2010, 09:17 AM
May your glass be smaller so it's always FULL! ![]() ![]() ![]() Group: Members Posts: 1,081 Joined: 10-June 08 From: Seattle Member No.: 9,160 Region Association: Pacific Northwest |
I like the enginering...very Corvair ISH.
NOW, what about just adding an electric fan on top instead of robbing any HP off the motor? RIGHT HERE! Is it possible???? ![]() Nice clean fan with the motor tucked inside, a pull design, smooth porsche gill over the top. ???? sorry, my .02 cents, free too! ![]() |
| SirAndy |
Jan 21 2010, 01:37 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,483 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
NOW, what about just adding an electric fan on top instead of robbing any HP off the motor? An electric fan costs you just the same amount of power by making the alternator work harder. Plus, you would still have to figure out how to make it turn in sync with the rpm, otherwise you overcool at low rpm ... No gain there ... (IMG:style_emoticons/default/shades.gif) Andy |
| bdstone914 |
Jan 21 2010, 10:05 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
NOW, what about just adding an electric fan on top instead of robbing any HP off the motor? An electric fan costs you just the same amount of power by making the alternator work harder. Plus, you would still have to figure out how to make it turn in sync with the rpm, otherwise you overcool at low rpm ... No gain there ... (IMG:style_emoticons/default/shades.gif) Andy Andy, There would be gains, or really less power consumption, with electric fans. Yes they use power but considerable less than mechanical fans. You can control the fan speed off of temperature rather than engine speed for better warm up and max cooling only when needed. I work for a company that offers a two speed fan with a 260 watt ( about 1/3 HP) motor and a two speed controler. There are other pulse with modulating controllers that can vary the fan speed. The power consumption of a mechanical increases with the cube ( power of 3) of the RPM. I recall that the old Corvair fan pulled about 20 hp at 8,000 fan RPM. I believe it was a 12" fan. Chris, It you want to try one out I can probably get a free sample. Bruce |
| Chris Hamilton |
Jan 24 2010, 06:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 611 Joined: 7-March 06 From: Berkeley, CA Member No.: 5,687 |
Andy, There would be gains, or really less power consumption, with electric fans. Yes they use power but considerable less than mechanical fans. You can control the fan speed off of temperature rather than engine speed for better warm up and max cooling only when needed. I work for a company that offers a two speed fan with a 260 watt ( about 1/3 HP) motor and a two speed controler. There are other pulse with modulating controllers that can vary the fan speed. The power consumption of a mechanical increases with the cube ( power of 3) of the RPM. I recall that the old Corvair fan pulled about 20 hp at 8,000 fan RPM. I believe it was a 12" fan. Chris, It you want to try one out I can probably get a free sample. Bruce That sounds cool! Can I get a sample to put on my car? Or at least a link to the manufacturer? I'm building a shroud with a half dozen triple blade deltas right now but if you have something much more powerful that can be controlled with PWM that'd be even better... |
Racer Chris Tangerine Racing Products Jan 21 2010, 03:48 AM
raw1298 looks great ! Jan 21 2010, 04:42 AM
watsonrx13 Looks great Chris... :headbanger:
If this is ins... Jan 21 2010, 05:44 AM
Racer Chris
If this is in... Jan 21 2010, 08:13 AM
lotus_65 Our kit will include aluminum sheetmetal to seal t... Jan 25 2010, 04:48 AM
Zimms It looks great. Any plans to test it against a hor... Jan 21 2010, 05:51 AM
Racer Chris
It looks great. Any plans to test it against a ho... Jan 21 2010, 09:08 AM
ottox914 Great, just great. I've been fantasizing abou... Jan 21 2010, 07:53 AM
dr914@autoatlanta.com "Take your Porsh and chev it" ? Jan 21 2010, 09:02 AM
Racer Chris
Um, I ... Jan 21 2010, 09:12 AM
dr914@autoatlanta.com I will never forget the time a flared 914 rolled i... Jan 21 2010, 01:25 PM
Racer Chris
It ended up having so much power that it would c... Jan 21 2010, 02:21 PM
dr914@autoatlanta.com (looks like a corvair engine!!!) Jan 21 2010, 09:03 AM
jaxdream Does look good :Qarl: :headbanger: , alternator c... Jan 21 2010, 09:12 AM
Racer Chris
What about alternator cooling ?? Oil filter appea... Jan 21 2010, 02:10 PM
ottox914
What about alternator cooling ?? Oil filter appe... Jan 21 2010, 06:13 PM
Racer Chris
- Would changing the alternator out to a more mod... Jan 21 2010, 08:31 PM
Racer Chris
Chris,
It you want to try one out I can probably... Jan 22 2010, 06:24 AM
ConeDodger
Andy,
There would be gains, or really less power... Feb 7 2010, 02:20 PM
Cap'n Krusty With the necessarily high tension on the belts at ... Jan 21 2010, 09:58 AM
Racer Chris
With the necessarily high tension on the belts at... Jan 21 2010, 02:04 PM
turboman808 Very cool! When will this be on a six. :pop... Jan 21 2010, 10:11 AM
kwales No, the electric fan isn't used for cooling, i... Jan 21 2010, 12:10 PM
URY914 Don't think that an electric motor driven fan ... Jan 21 2010, 12:30 PM
Racer Chris
Don't think that an electric motor driven fan... Jan 21 2010, 02:17 PM
RobW Awesome. :beer1: Jan 21 2010, 01:30 PM
flipb If you reverse the direction of the fan, would you... Jan 21 2010, 02:15 PM
URY914 And the belts are much better these days then in y... Jan 21 2010, 03:25 PM
Phoenix 914-6GT Wow :drooley: You sure do come up with some cool s... Jan 21 2010, 04:45 PM
Brando Chris if I still had a 914 I would have loved to b... Jan 21 2010, 09:37 PM
Racer Chris My CAD guy gave me this animation the other day.
T... Jan 24 2010, 05:03 PM
Racer Chris Here are pics of the latest progress. Jan 24 2010, 05:49 PM
ericread Finally! A 914 hovercraft!!!
:lo... Jan 24 2010, 06:42 PM
URY914 Chris, is the aluminum several pieces you tig... Jan 24 2010, 07:37 PM
Racer Chris
Chris, is the aluminum several pieces you tig... Jan 25 2010, 05:55 AM
Dr Evil Bang on corvair as it is belt driven vs gear drive... Jan 24 2010, 10:07 PM
turnaround89 How much is the cost going to be for this setup? Jan 25 2010, 01:30 AM
rdauenhauer
I was wondering about this..It dosent look like t... Jan 25 2010, 08:46 AM
Racer Chris
I was wondering about this..It dosent look like t... Jan 26 2010, 08:07 PM
nsr-jamie Chris, first want to thank you for sending me thos... Jan 25 2010, 08:53 AM
Racer Chris
Will you make the sheetmetal in carbon fiber? (Th... Jan 26 2010, 08:13 PM
Dr Evil That looks so bad ass :trophy: Jan 26 2010, 08:30 PM
Rod Cool. Well let's hope so ;)
Looking great. ... Jan 27 2010, 03:20 AM
Racer Chris
a more modern alternative with a higher output wo... Jan 27 2010, 06:16 AM
Rod
a more modern alternative with a higher output w... Jan 27 2010, 10:41 AM
r_towle I saw this setup today and it looked great. I thin... Feb 6 2010, 04:20 PM
Racer Chris It was good to see you Rich!
Here's how i... Feb 7 2010, 12:23 PM
Brando Chris,
Would it be possible to show an intercooler... Feb 7 2010, 05:19 PM
ottox914
Chris,
Would it be possible to show an intercoole... Feb 8 2010, 08:10 AM
Racer Chris
Would it be possible to show an intercooler place... Feb 8 2010, 08:23 AM
Racer Chris I'm working on a wooden buck to form more alum... Feb 16 2010, 12:21 PM
Cevan I saw this in person last week (needed my annual B... Feb 16 2010, 02:07 PM
Racer Chris Production of the first batch has begun.
For a lim... Feb 18 2010, 11:43 AM
Racer Chris Here's an Audi TT intercooler sitting on my th... Feb 24 2010, 12:16 PM
Racer Chris And here's a pic of the wooden form I've b... Feb 24 2010, 12:23 PM
Dr Evil Very cool process. Thanks for posting. Feb 24 2010, 02:00 PM
FourBlades How much additional engine horsepower output do yo... Feb 24 2010, 02:45 PM
Racer Chris
How did you make the wooden buck? Belt sander?
I... Feb 24 2010, 04:45 PM
Racer Chris
How much additional engine horsepower output do y... Mar 2 2010, 05:25 PM
Racer Chris Here's a pic of the first "pilot producti... Mar 2 2010, 05:09 PM
lancelotIV wow, Chris! this looks GREAT! You've c... Mar 29 2010, 03:50 PM
Racer Chris
How much are you thinking this system will weigh... Mar 29 2010, 07:13 PM
r_towle How about composite pulleys and associated bracket... Mar 29 2010, 07:33 PM
Racer Chris
How about composite pulleys and associated bracke... Mar 29 2010, 07:49 PM
r_towle Yet drive down the weight.
Composite pulleys can ... Mar 29 2010, 07:50 PM
Racer Chris
BTW, did you dig up the iron and smelt it, then f... Mar 29 2010, 08:44 PM
r_towle The story of creating the buck is lacking some ver... Mar 29 2010, 08:48 PM
Racer Chris
The story of creating the buck is lacking some ve... Mar 30 2010, 09:37 AM
rick 918-S Very nice work Chris! You are a machine! :... Mar 29 2010, 10:50 PM
Brando The setup is so sexy with that intercooler.
I rea... Mar 29 2010, 10:55 PM
Krieger914 Chris how the hell did you know 26 years ago that ... Mar 30 2010, 08:21 PM
Racer Chris It was the same year I bought my tangerine 914. :D Mar 30 2010, 09:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th June 2026 - 12:22 AM |
