> TRANSMISSION REBUILD VIDEO THREAD, Input sought!
Dr Evil
post Jan 24 2010, 01:39 PM
Send me your transmission!
The video is getting closer to happening as Eric (cupomeat) and I just work on firming up a date in the near future. The video will cover the full tear down, inspection and rebuild of both side and tail shift (both /4 and /6) transmissions, but the video can not cover everything that I wish to. As such, I have taken the last 4 days in the middle of nowhere MN to start writing the notes that will accompany the video. The notes may be made available for free as well at a later time, but for now I need to make sure that they are as complete as I can make them. I have much of them done already, but I am still in the editing phase. If you have some info (factual or anecdotal) or experience with any of the topics, feel free to post them so I can either shoot them down or include them (IMG:style_emoticons/default/wink.gif)
Here is the outline so far:
Transmission rebuild video supplement:
Forward
– What the deal is
Chapter 1 – Do I need a rebuild?
What external things to inspect
*Engine mounts
*Trans mounts
*Bushings
*Cone screws
*Clutch cable adjustment and issues
-How to adjust cable
-Broken tube
How to adjust the shifter
Inspecting core tranny
*Input shaft and output flanges turn?
*Input shaft play?
*“it shifts fine on the floor”, Oh goody, big deal.
A word on reading used transmission oil
Chapter 2 – Do I need that?
Myths and musings
*Billet intermediate plate
*Through bolting the intermediate plate/case/tail cone
*Lubricants
-Dino vs Royal Purple vs Swepco
*Galvanic chart: Stainless hardware FACTS
-SS hardware will not prematurely corrode your case and why not
*Corrosion protection
-Original factory coating
-Options for aftermarket
Chapter 3 – Tweaking your gears and diff
Gear selection
*Considerations
*Engine dependent gearing
*Interpreting gearing
*Intended usage of the gear box
*Flipping gears
Limited slip differentials
*The main idea - what they do
*Torque biasing
*Friction biasing
Welded differentials
*Don't do it!
Chapter 4
– Troubleshooting, care, and feeding of your 901
Problem list
*Reverse gear grinds
*Pops out of gear
*Grinds
*Whining
*Clutch will not disengage – resurfaced flywheel usage?
*Clunk and shifts funny
*Pivot ball leak?
General maintenance
*Oil changing
Appendix
Torques and values
*Case nuts, 8x1.25
*Speedo retainer bolt
*Throwout bearing guide tubs nuts, 10x?
*Detente package retainer bolt, 14mm
*Pinion bolt
*Input shaft nut
Special tools list
detoxcowboy
post Jan 24 2010, 09:46 PM
Region Association: Africa
Dr. Evil,
Maybe something on using used parts vs. new, You had mentioned to me that on some level used parts of a specific desighn would be better than a new replcement, and also led to the hint that replaceing certain parts with good used would be just as effective.. Maybe something along that line as looking at rebuilding yourself is daunting but adding up the potential new replacement cost is intimidaiting too.. Joe
Dr Evil   TRANSMISSION REBUILD VIDEO THREAD   Jan 24 2010, 01:39 PM
underthetire   Special tool list please.   Jan 24 2010, 01:48 PM
Gint   Special tool list please.Reasonable substitutes fo...   Jan 24 2010, 10:17 PM
Gint   Special tool list please.Reasonable substitutes fo...   Jan 25 2010, 02:06 PM
Dr Evil   [quote name='Gint' post='1265333' date='Jan 24 20...   Jan 25 2010, 02:12 PM
Dr Evil   Good idea! Added to the first post. I will inc...   Jan 24 2010, 02:03 PM
jmill   How about a section on selecting gear ratios for y...   Jan 24 2010, 02:14 PM
rick 918-S   Speciality tools as an option when purchasing a vi...   Jan 24 2010, 02:22 PM
ericread   Where are the step-by-step instructions of tearing...   Jan 24 2010, 02:31 PM
smontanaro   ... I need is a refresher from when I crack the ca...   Jan 24 2010, 02:46 PM
Dr Evil   Um, Eric, the video is intended to cover those thi...   Jan 24 2010, 09:22 PM
ericread   Um, Eric, the video is intended to cover those th...   Jan 25 2010, 09:11 AM
Dr Evil   I have the chapters 1 and 3 done for review. I wil...   Jan 24 2010, 09:28 PM
FourBlades   Maybe say a few words about converting tail shifte...   Jan 24 2010, 09:28 PM
Dr Evil   Maybe say a few words about converting tail shift...   Jan 24 2010, 09:38 PM
Dr Evil   Chapter 1 – “Do I even need a rebuild?” Wha...   Jan 24 2010, 09:34 PM
Dr Evil   [u]Chapter 3 – Tweaking your gears and diff [b]...   Jan 24 2010, 09:37 PM
detoxcowboy   Dr. Evil, Maybe something on using used parts...   Jan 24 2010, 09:46 PM
Dr Evil   That will be in the video :)   Jan 24 2010, 09:51 PM
detoxcowboy   Dr. Evil Anything about indexing the shift rod to...   Jan 24 2010, 10:30 PM
Dr Evil   Crap, I totally forgot to add the shift adjustment...   Jan 24 2010, 11:01 PM
computers4kids   I know your producing a DVD, but how about also cr...   Jan 25 2010, 09:44 AM
Dr Evil   I know you producing a DVD, but how about also cr...   Jan 25 2010, 02:14 PM
turboman808   I'll see if Eric has any idea about this. I ...   Jan 25 2010, 02:55 PM
Dr Evil   I'll see if Eric has any idea about this. I...   Jan 25 2010, 06:34 PM
charliew   Mike I'm sure you have also thought about the ...   Jan 25 2010, 10:10 AM
Dr Evil   Mike I'm sure you have also thought about the...   Jan 25 2010, 02:09 PM
kwales   Evil, Hows about a little dialoge on dos and don...   Jan 25 2010, 11:52 AM
Dr Evil   Evil, Hows about a little dialoge on dos and don...   Jan 25 2010, 02:10 PM
RoadGlue   Hey Mike, this is awesome! Let me know if I ca...   Jan 25 2010, 02:01 PM
bandjoey   It'd only take about a weeks worth of producti...   Jan 26 2010, 05:02 PM
Dr Evil   I hope it is not just informative, but also entert...   Jan 26 2010, 05:35 PM
Dr Evil   OK, Folks! The date for shooting this has been...   Feb 4 2010, 11:13 AM
- Lo-Fi Version Time is now: 1st July 2025 - 10:34 PM
