Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
The video is getting closer to happening as Eric (cupomeat) and I just work on firming up a date in the near future. The video will cover the full tear down, inspection and rebuild of both side and tail shift (both /4 and /6) transmissions, but the video can not cover everything that I wish to. As such, I have taken the last 4 days in the middle of nowhere MN to start writing the notes that will accompany the video. The notes may be made available for free as well at a later time, but for now I need to make sure that they are as complete as I can make them. I have much of them done already, but I am still in the editing phase. If you have some info (factual or anecdotal) or experience with any of the topics, feel free to post them so I can either shoot them down or include them (IMG:style_emoticons/default/wink.gif)
Here is the outline so far: Transmission rebuild video supplement: Forward – What the deal is Chapter 1 – Do I need a rebuild? What external things to inspect *Engine mounts *Trans mounts *Bushings *Cone screws *Clutch cable adjustment and issues -How to adjust cable -Broken tube How to adjust the shifter Inspecting core tranny *Input shaft and output flanges turn? *Input shaft play? *“it shifts fine on the floor”, Oh goody, big deal. A word on reading used transmission oil Chapter 2 – Do I need that? Myths and musings *Billet intermediate plate *Through bolting the intermediate plate/case/tail cone *Lubricants -Dino vs Royal Purple vs Swepco *Galvanic chart: Stainless hardware FACTS -SS hardware will not prematurely corrode your case and why not *Corrosion protection -Original factory coating -Options for aftermarket Chapter 3 – Tweaking your gears and diff Gear selection *Considerations *Engine dependent gearing *Interpreting gearing *Intended usage of the gear box *Flipping gears Limited slip differentials *The main idea - what they do *Torque biasing *Friction biasing Welded differentials *Don't do it! Chapter 4 – Troubleshooting, care, and feeding of your 901 Problem list *Reverse gear grinds *Pops out of gear *Grinds *Whining *Clutch will not disengage – resurfaced flywheel usage? *Clunk and shifts funny *Pivot ball leak? General maintenance *Oil changing Appendix Torques and values *Case nuts, 8x1.25 *Speedo retainer bolt *Throwout bearing guide tubs nuts, 10x? *Detente package retainer bolt, 14mm *Pinion bolt *Input shaft nut Special tools list |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
Special tool list please.
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Special tool list please. Reasonable substitutes for special tools. (IMG:style_emoticons/default/idea.gif) |
Gint |
Dr Evil |
Special tool list please. Reasonable substitutes for special tools. (IMG:style_emoticons/default/idea.gif)This is a problem area in that I have some modified tools, but for that actual special tools, I only use the correct tools. Using anything else can be dangerous to you and your parts. I havent used many substitutions so I really cant comment. |
Lo-Fi Version | Time is now: 1st July 2025 - 09:37 PM |
