> Front Brakes Dragging, wheels don't spin free
7TPorsh
post Jan 25 2010, 03:28 PM
7T Porsh
Tried looking in search...
I changed out the following;
- Front brake rotors
- Front bearings and seals
- Front pads
I tried to push back the piston enough to get the pads in...ending up tapping them in but not too much effort. I noticed that it was tight. Thinking it will loosen up, i finished the job.
I get the car on the ground and out on the road a little and realize that the car just doesn't roll...i am working against the brakes. Brakes didn't 'adjust" and are still really tight. Lock nut is not overly tightened.
7TPorsh
post Jan 25 2010, 03:44 PM
7T Porsh
off the ground they don't spin. I have to grab it and turn...it's really tight. Both sides are the same.
The brake pedal works and stops the car fast when driving; but I have to floor it in 2nd gear to keep it at 25mph.
Venting??
Mike Bellis
post Jan 25 2010, 03:51 PM
Resident Electrician
QUOTE(7TPorsh @ Jan 25 2010, 01:44 PM) *
Venting??
Remove the callipers. Do they spin? While spinning the rotor, tighten the lock nut until it stops spinning. back the nut off 1/4 turn. install the calliper. slam on the brakes a couple of times. try to spin the wheel.
7TPorsh   Front Brakes Dragging   Jan 25 2010, 03:28 PM
kg6dxn   Technically disc brakes should drag a little. with...   Jan 25 2010, 03:34 PM
914Sixer   Jack up each wheel and spin them. Find out which ...   Jan 25 2010, 03:34 PM
7TPorsh   off the ground they don't spin. I have to grab...   Jan 25 2010, 03:44 PM
kg6dxn   off the ground they don't spin. I have to gra...   Jan 25 2010, 03:51 PM
etcmss   did the bearings go on easily and is the rotor ful...   Jan 25 2010, 03:52 PM
dr914@autoatlanta.com   and make sure that the pedal itself is not stickin...   Jan 25 2010, 03:51 PM
bandjoey   Are the clearance clips in place on the pistons? ...   Jan 25 2010, 03:56 PM
Eric_Shea   :huh: (those are piston positioning clips meant...   Jan 25 2010, 04:26 PM
etcmss   Eric -are you saying the hose(s) actually get a bu...   Jan 26 2010, 04:14 PM
jmill   Eric -are you saying the hose(s) actually get a b...   Jan 26 2010, 05:04 PM
7TPorsh   I don't think it's the lines but will look...   Jan 26 2010, 05:39 PM
underthetire   Ok, just gotta ask here. New pads (thicker than ol...   Jan 26 2010, 06:02 PM
ahdoman   another thought - If, when you took the calipers o...   Jan 26 2010, 06:41 PM
Cap'n Krusty   '70-'71 and most '72s took the T4 roto...   Jan 26 2010, 07:04 PM
Eric_Shea   The caliper offset is quite different. I doubt ...   Jan 26 2010, 11:51 PM
sean_v8_914   frozen caliper pistons. dark brown nasty brake flu...   Jan 27 2010, 08:47 AM
ME733   ......AND when everything mentioned has been check...   Jan 27 2010, 11:14 AM
7TPorsh   ......AND when everything mentioned has been chec...   Jan 27 2010, 05:22 PM
etcmss   Pelican-- http://www.pelicanparts.com/catalog/shop...   Jan 27 2010, 06:08 PM
topatrout914   Make sure you did not overtighten the spindle nut....   Jan 28 2010, 10:09 AM
ME733   I purchased the "expanding Springs,".......   Jan 28 2010, 01:48 PM
7TPorsh   i looked at Pelican, it looks like they only have ...   Jan 28 2010, 02:19 PM
914rrr   Resurrecting an older thread that eliminates some ...   Oct 23 2026, 12:28 PM
4 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
1 Members: T.Rick6
- Lo-Fi Version Time is now: 23rd October 2026 - 05:24 PM
