| 7TPorsh |
Jan 25 2010, 03:28 PM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
Tried looking in search...
I changed out the following; - Front brake rotors - Front bearings and seals - Front pads I tried to push back the piston enough to get the pads in...ending up tapping them in but not too much effort. I noticed that it was tight. Thinking it will loosen up, i finished the job. I get the car on the ground and out on the road a little and realize that the car just doesn't roll...i am working against the brakes. Brakes didn't 'adjust" and are still really tight. Lock nut is not overly tightened. |
| 7TPorsh |
Jan 25 2010, 03:44 PM
off the ground they don't spin. I have to grab it and turn...it's really tight. Both sides are the same.
The brake pedal works and stops the car fast when driving; but I have to floor it in 2nd gear to keep it at 25mph. Venting?? |
| etcmss |
Jan 25 2010, 03:52 PM
etcmss ![]() ![]() Group: Members Posts: 183 Joined: 20-April 06 From: Lancaster, Ky Member No.: 5,899 Region Association: Upper MidWest |
did the bearings go on easily and is the rotor fully seated? Lastly is there clearance in the brake pad to caliper?
7TPorsh Front Brakes Dragging Jan 25 2010, 03:28 PM
kg6dxn Technically disc brakes should drag a little. with... Jan 25 2010, 03:34 PM
914Sixer Jack up each wheel and spin them. Find out which ... Jan 25 2010, 03:34 PM
kg6dxn
off the ground they don't spin. I have to gra... Jan 25 2010, 03:51 PM
dr914@autoatlanta.com and make sure that the pedal itself is not stickin... Jan 25 2010, 03:51 PM
bandjoey Are the clearance clips in place on the pistons? ... Jan 25 2010, 03:56 PM
Eric_Shea
:huh: (those are piston positioning clips meant... Jan 25 2010, 04:26 PM
etcmss Eric -are you saying the hose(s) actually get a bu... Jan 26 2010, 04:14 PM
jmill
Eric -are you saying the hose(s) actually get a b... Jan 26 2010, 05:04 PM
7TPorsh I don't think it's the lines but will look... Jan 26 2010, 05:39 PM
underthetire Ok, just gotta ask here. New pads (thicker than ol... Jan 26 2010, 06:02 PM
ahdoman another thought - If, when you took the calipers o... Jan 26 2010, 06:41 PM
Cap'n Krusty '70-'71 and most '72s took the T4 roto... Jan 26 2010, 07:04 PM
Eric_Shea
The caliper offset is quite different. I doubt ... Jan 26 2010, 11:51 PM
sean_v8_914 frozen caliper pistons. dark brown nasty brake flu... Jan 27 2010, 08:47 AM
ME733 ......AND when everything mentioned has been check... Jan 27 2010, 11:14 AM
7TPorsh
......AND when everything mentioned has been chec... Jan 27 2010, 05:22 PM
etcmss Pelican-- http://www.pelicanparts.com/catalog/shop... Jan 27 2010, 06:08 PM
topatrout914 Make sure you did not overtighten the spindle nut.... Jan 28 2010, 10:09 AM
ME733 I purchased the "expanding Springs,"....... Jan 28 2010, 01:48 PM
7TPorsh i looked at Pelican, it looks like they only have ... Jan 28 2010, 02:19 PM
914rrr Resurrecting an older thread that eliminates some ... Oct 23 2026, 12:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd October 2026 - 05:23 PM |
