machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
I really want to make our next race weekend with the SCCA in about 1 month.
The 1.7 is on its 9th life. I am amazed how this little motor just keeps going and going after 30 years and god knows how many miles. I have run 7 races and 2 test days with the motor and it won't quit. Finish in the top 1/3 in my group too. Anyway I have the 2.0 now and was thinking of doing the top end and putting on 40 IDF's. I would have the heads done at HFM and use a set of 96's from brad or maybe mahles. How do I know if the bottom end of the motor is OK? I have read that running carbs with the stock cam loses power and I have read you can gain a bit. What Think? dr |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(synthesisdv @ Feb 26 2004, 01:57 PM) How do I know if the bottom end of the motor is OK? I have read that running carbs with the stock cam loses power and I have read you can gain a bit. rod bearings have a hard life in our motors. "As Long As" the heads and cylinders are off, have a look at the rod bearings and mike the crankthrows. if they're decent, and there are no other indications of main bearing issues (excessive thrust, for instance) and the cam lobes look good, you might be more inclined to believe the mains are good too. if the rod bearings show signs of abuse, i'd think you'd have to be a little skeptical about the mains too. while the rods are out is a good time to have them reconditioned and balanced if you're inclined to do such a thing. since the OEM injection doesn't really show any indication of excessive leanness over its operating range, i wouldn't think there's that much to be gained by changing from injection to carbs with the stock cam. maybe if freshly ported heads can flow more air at the stock rev ranges, and if increased compression (power) results in a requirement for more fuel, there could be some gains, i suppose ... |
Lo-Fi Version | Time is now: 11th July 2025 - 05:08 PM |
