> Valve adjustment tips?, Do I need a trained monkey or what?
mpoffers
post Feb 6 2010, 07:12 PM
Got the car on jackstands, valve covers are off, I'm turning the engine and rocking the valves per instructions from a forum search. All is well.
Except I can't reach the valves. There's engine tin above, heat exchanger below, and suspension mount to the side. OK, I'm exagerating a little. I can reach the rockers, I can even get the feeler gage in and out. What I can't see how to do is get tools in there to do the adjustment. I might be able to get a wrench on the lock nut and get it loose, but I don't see how I could get it tight enough after I've made the adjustment. I definately don't see how I could hold the adjustment screw and tighten the nut simultaneously.
Am I missing something, or should I be recruiting the help of my 4-year-old-daughter? Her hands are pretty small.
Mike
Markl
post Feb 6 2010, 09:45 PM
I am not going to disagree with the masters on this board, but I think that every few thousand miles I would want to check/clean my heat exchangers and exhaust system. Once they are removed, you have plenty of room to adjust valves, check for leaks, clean, free up exhaust header nuts, clean and paint warm air guides, check/clean thermostat, etc., anything you can think of - maybe the best look you'll get at your engine without dropping it. Come to think of it, that's probably an even better way!
rjames
post Feb 6 2010, 11:23 PM
I'm made of metal
QUOTE(Markl @ Feb 6 2010, 07:45 PM) *
Besides making it expensive for us CSOB's to have to replace those copper heat exchanger nuts and copper gaskets every time the heat exchangers are reinstalled, those of us who have found stripped exhaust studs (and fixed them) really aren't in to removing the heat exchangers unless it's absolutely necessary. For me, a valve adjustment doesn't qualify.
mpoffers   Valve adjustment tips?   Feb 6 2010, 07:12 PM
Kirmizi   A feeler gauge, short screwdriver, wrench and pati...   Feb 6 2010, 07:31 PM
Dave_Darling   I use a stubby flat-head screwdriver. I also use ...   Feb 6 2010, 07:39 PM
Cap'n Krusty   I wondered the same thing when I did my first one ...   Feb 6 2010, 07:47 PM
hot_shoe914   I use a 54 year old grumpy mechanic. Easy as pie a...   Feb 6 2010, 08:17 PM
76-914   I use a 54 year old grumpy mechanic. Easy as pie ...   Feb 7 2010, 01:01 PM
klink   OK, I tried to do this the fast way and it didn...   Feb 6 2010, 08:31 PM
Cap'n Krusty   OK, I tried to do this the fast way and it didn...   Feb 7 2010, 10:11 AM
ericread   Sorry, Dude, but the problems you had are OPERATO...   Feb 7 2010, 01:47 PM
Markl   I am not going to disagree with the masters on thi...   Feb 6 2010, 09:45 PM
rjames   I am not going to disagree with the masters on th...   Feb 6 2010, 11:23 PM
Markl   Never mind all that, go ahead and get a trained mo...   Feb 6 2010, 09:48 PM
Markl   Agreed, I guess - taking the exhaust headers off i...   Feb 7 2010, 12:44 AM
Gint   Almost every valve adjuster screw on every Type IV...   Feb 7 2010, 08:59 AM
kwales   If you have ever tightened a valve adjuster nut on...   Feb 7 2010, 10:26 AM
Gint   If you have ever tightened a valve adjuster nut on...   Feb 7 2010, 12:46 PM
yeahmag   I haven't needed to use a screw driver to adju...   Feb 7 2010, 11:39 AM
bandjoey   Dime is a great screwdriver because you can better...   Feb 7 2010, 03:33 PM
vsg914   Do it the Cap'ns way. Hardest part is crawling...   Feb 7 2010, 03:47 PM
klink   Looks like I'll be trying the Cap'ns way t...   Feb 7 2010, 05:34 PM
mpoffers   So there's no magic trick. Offset wrenches mi...   Feb 7 2010, 10:50 PM
kwales   Yup, I started doing the valve adjust the same wa...   Feb 8 2010, 09:01 AM
detoxcowboy   RE: Valve adjustment tips?   Feb 8 2010, 09:36 AM
windforfun   http://www.euroquattro.com/index.htm Ask for Tony...   Feb 8 2010, 06:22 PM
- Lo-Fi Version Time is now: 9th June 2026 - 11:59 PM
