> Valve adjustment tips?, Do I need a trained monkey or what?
mpoffers
post Feb 6 2010, 07:12 PM
Got the car on jackstands, valve covers are off, I'm turning the engine and rocking the valves per instructions from a forum search. All is well.
Except I can't reach the valves. There's engine tin above, heat exchanger below, and suspension mount to the side. OK, I'm exagerating a little. I can reach the rockers, I can even get the feeler gage in and out. What I can't see how to do is get tools in there to do the adjustment. I might be able to get a wrench on the lock nut and get it loose, but I don't see how I could get it tight enough after I've made the adjustment. I definately don't see how I could hold the adjustment screw and tighten the nut simultaneously.
Am I missing something, or should I be recruiting the help of my 4-year-old-daughter? Her hands are pretty small.
Mike
hot_shoe914
post Feb 6 2010, 08:17 PM
on ramp passer
I use a 54 year old grumpy mechanic. Easy as pie and have yet to get my hands dirty. (IMG:style_emoticons/default/piratenanner.gif)
post Feb 7 2010, 01:01 PM
QUOTE(hot_shoe914 @ Feb 6 2010, 06:17 PM) *
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/laugh.gif) Yea, but doesn't that get expensive flying Cap'n (IMG:style_emoticons/default/mad.gif) Krusty back 'n forth from California? (IMG:style_emoticons/default/lol-2.gif)
mpoffers   Valve adjustment tips?   Feb 6 2010, 07:12 PM
Kirmizi   A feeler gauge, short screwdriver, wrench and pati...   Feb 6 2010, 07:31 PM
Dave_Darling   I use a stubby flat-head screwdriver. I also use ...   Feb 6 2010, 07:39 PM
Cap'n Krusty   I wondered the same thing when I did my first one ...   Feb 6 2010, 07:47 PM
hot_shoe914   I use a 54 year old grumpy mechanic. Easy as pie a...   Feb 6 2010, 08:17 PM
76-914   I use a 54 year old grumpy mechanic. Easy as pie ...   Feb 7 2010, 01:01 PM
klink   OK, I tried to do this the fast way and it didn...   Feb 6 2010, 08:31 PM
Cap'n Krusty   OK, I tried to do this the fast way and it didn...   Feb 7 2010, 10:11 AM
ericread   Sorry, Dude, but the problems you had are OPERATO...   Feb 7 2010, 01:47 PM
Markl   I am not going to disagree with the masters on thi...   Feb 6 2010, 09:45 PM
rjames   I am not going to disagree with the masters on th...   Feb 6 2010, 11:23 PM
Markl   Never mind all that, go ahead and get a trained mo...   Feb 6 2010, 09:48 PM
Markl   Agreed, I guess - taking the exhaust headers off i...   Feb 7 2010, 12:44 AM
Gint   Almost every valve adjuster screw on every Type IV...   Feb 7 2010, 08:59 AM
kwales   If you have ever tightened a valve adjuster nut on...   Feb 7 2010, 10:26 AM
Gint   If you have ever tightened a valve adjuster nut on...   Feb 7 2010, 12:46 PM
yeahmag   I haven't needed to use a screw driver to adju...   Feb 7 2010, 11:39 AM
bandjoey   Dime is a great screwdriver because you can better...   Feb 7 2010, 03:33 PM
vsg914   Do it the Cap'ns way. Hardest part is crawling...   Feb 7 2010, 03:47 PM
klink   Looks like I'll be trying the Cap'ns way t...   Feb 7 2010, 05:34 PM
mpoffers   So there's no magic trick. Offset wrenches mi...   Feb 7 2010, 10:50 PM
kwales   Yup, I started doing the valve adjust the same wa...   Feb 8 2010, 09:01 AM
detoxcowboy   RE: Valve adjustment tips?   Feb 8 2010, 09:36 AM
windforfun   http://www.euroquattro.com/index.htm Ask for Tony...   Feb 8 2010, 06:22 PM
- Lo-Fi Version Time is now: 10th June 2026 - 12:03 AM
