| mpoffers |
Feb 6 2010, 07:12 PM
Member ![]() ![]() Group: Members Posts: 52 Joined: 15-September 08 From: Portland, OR Member No.: 9,551 Region Association: Pacific Northwest |
Got the car on jackstands, valve covers are off, I'm turning the engine and rocking the valves per instructions from a forum search. All is well. Except I can't reach the valves. There's engine tin above, heat exchanger below, and suspension mount to the side. OK, I'm exagerating a little. I can reach the rockers, I can even get the feeler gage in and out. What I can't see how to do is get tools in there to do the adjustment. I might be able to get a wrench on the lock nut and get it loose, but I don't see how I could get it tight enough after I've made the adjustment. I definately don't see how I could hold the adjustment screw and tighten the nut simultaneously. Am I missing something, or should I be recruiting the help of my 4-year-old-daughter? Her hands are pretty small. Mike |
| Katmanken |
Feb 8 2010, 09:01 AM
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Yup,
I started doing the valve adjust the same way as the Captain back in the 70's. It's a bit of a pain going back and forth -rotating the engine and looking at a valve on one side until it goes full in, and then moving to the other side of the engine and adjusting the exact opposite valve. But, can't argue with results. Got 200,000 on my Superbeetle engine with valve adjusts and oil changes. |
mpoffers Valve adjustment tips? Feb 6 2010, 07:12 PM
Kirmizi A feeler gauge, short screwdriver, wrench and pati... Feb 6 2010, 07:31 PM
Dave_Darling I use a stubby flat-head screwdriver. I also use ... Feb 6 2010, 07:39 PM
Cap'n Krusty I wondered the same thing when I did my first one ... Feb 6 2010, 07:47 PM
hot_shoe914 I use a 54 year old grumpy mechanic. Easy as pie a... Feb 6 2010, 08:17 PM
76-914
I use a 54 year old grumpy mechanic. Easy as pie ... Feb 7 2010, 01:01 PM
klink OK, I tried to do this the fast way and it didn... Feb 6 2010, 08:31 PM
Cap'n Krusty
OK, I tried to do this the fast way and it didn... Feb 7 2010, 10:11 AM
ericread
Sorry, Dude, but the problems you had are OPERATO... Feb 7 2010, 01:47 PM
Markl I am not going to disagree with the masters on thi... Feb 6 2010, 09:45 PM
rjames
I am not going to disagree with the masters on th... Feb 6 2010, 11:23 PM
Markl Never mind all that, go ahead and get a trained mo... Feb 6 2010, 09:48 PM
Markl Agreed, I guess - taking the exhaust headers off i... Feb 7 2010, 12:44 AM
Gint Almost every valve adjuster screw on every Type IV... Feb 7 2010, 08:59 AM
kwales If you have ever tightened a valve adjuster nut on... Feb 7 2010, 10:26 AM
Gint If you have ever tightened a valve adjuster nut on... Feb 7 2010, 12:46 PM
yeahmag I haven't needed to use a screw driver to adju... Feb 7 2010, 11:39 AM
bandjoey Dime is a great screwdriver because you can better... Feb 7 2010, 03:33 PM
vsg914 Do it the Cap'ns way. Hardest part is crawling... Feb 7 2010, 03:47 PM
klink Looks like I'll be trying the Cap'ns way t... Feb 7 2010, 05:34 PM
mpoffers So there's no magic trick. Offset wrenches mi... Feb 7 2010, 10:50 PM
detoxcowboy RE: Valve adjustment tips? Feb 8 2010, 09:36 AM
windforfun http://www.euroquattro.com/index.htm
Ask for Tony... Feb 8 2010, 06:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th June 2026 - 12:02 AM |
