H4 conversion - good deal? |
Cevan |
Feb 9 2010, 01:28 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Bus Depot has the H4 bulbs and housings for about $53 total. These are the E-code housing which are approved for motorcycles. Any reason these won't work fine on our cars, apart from the "approved for motorcycle use" issue?
914Sixer |
Feb 9 2010, 04:38 PM
914 Guru Group: Members Posts: 8,898 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
One thing to consider using H4 is the fact that they hang upside down when stored. The bulb is not sealed and the rubber seal that goes around the bulb has been know to leak. The other factor is that the seal fries under the metal of the headlight cover. I prefer Halogen Sealbeam because they work just as good and are available most places. With higher than stock watt bulbs (100W) you may or may not need a relay to keep wiring temp down.
Lo-Fi Version | Time is now: 2nd June 2024 - 04:00 PM |
