Hoosier Wets - Wide Rims or Narrow Rims, Is it better to use narrow or wide rims with wet tires? |
Eddie914 |
Feb 8 2010, 07:00 PM
Unregistered |
I was just given some usable Hoosier Wet Radials in 225/50/16 and 245/45/16 sizes.
I have the following two sets of wheels to mount these tires: Fachs - 16x7 front, 16x8 rear BBS 16x8 front, Compomotive 16x9 rear I have never run Hoosier Wet Radials. They seem to be quite wide for the stated size. Should I mount the Hoosiers on the 16x7/8 or 16x8/9 wheels? My teener is a 1971 914-6 conversion (3.2) with flares at about 2050 lbs. For dry tires I run Toyo RA1 225/50/16 and 245/45/16 on BBS E50 16x8 & 16x9 wheels. Thanks Eddie |
ME733 |
Feb 11 2010, 01:21 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
..........Generally for performance, radial tires like a stright as possable SIDEWALL , this may mean that with your measurement that the hoosiers are wider than the other tires, you will be better off with the wider rims...........mm.
Lo-Fi Version | Time is now: 6th June 2024 - 06:14 PM |
