| Vysoc |
Feb 12 2010, 07:18 AM
Vysoc ![]() ![]() ![]() Group: Members Posts: 589 Joined: 27-August 09 From: NorthWest Arkansas Member No.: 10,737 Region Association: Southwest Region |
1975 - 2.0 D-Jet Stock Fuel Injection
Recently fitted with 73 GA 2.0 engine all fuel injection components are from the 75. We have everything installed, fuel pressure through the lines is correct 28PSI, we do not seem to be receiving a signal on crank to the cold start valve, where does this signal originate? We are also not receiving a signal to fuel injectors during cranking? When we manually prime the plenum we can hear the injectors clicking but when we turn the key to the on position, we here the fuel pump prime but do not hear the injectors click? At this point the engine wants to fire but will not, obviously there is not enough fuel getting to the intake? Signal at the coil seems to be correct. What next? Thanks, Vysoc (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/confused24.gif) |
| Bleyseng |
Feb 12 2010, 07:58 AM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Do the injectors spray fuel? Pull one and stick it in a glass jar and have a friend turn over the engine AFTER pull the coil to dizzy wire.
Do you have spark? After putting the injector back together, grab a extra plug and pull of spark plug connector off a plug and connect it to the extra plug. Using a set of insulated pliers to grab it, ground it to the engine while a friend turns over the engine. You should have a nice bright spark on the plug. The CSV should only work at 42F and under so depending on the temp it will or won't work. |
| pbanders |
Feb 12 2010, 08:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 990 Joined: 11-June 03 From: Scottsdale, AZ Member No.: 805 Region Association: Southwest Region |
Do the injectors spray fuel? Pull one and stick it in a glass jar and have a friend turn over the engine AFTER pull the coil to dizzy wire. Do you have spark? After putting the injector back together, grab a extra plug and pull of spark plug connector off a plug and connect it to the extra plug. Using a set of insulated pliers to grab it, ground it to the engine while a friend turns over the engine. You should have a nice bright spark on the plug. The CSV should only work at 42F and under so depending on the temp it will or won't work. Some thermo switches and thermo-time switches (which determine if the CSV will turn on) don't switch until less than 32 deg. F. I don't think mine's been cold enough to operate for 20 years! :-) Like Geoff says, first make sure you're getting spark. When you turn the key, the fuel pump runs for ~3 seconds to pressurize the fuel line. The injectors don't fire until you start cranking. If you want to see if you're getting signal to the injectors, buy a cheap "noid" light from your local auto parts store. You pull the cable going to an injector and plug in the noid light. When you crank, you should see it flashing. Spraying in some starting fluid will also help determine where your problem is. |
| Bleyseng |
Feb 13 2010, 11:15 AM
Do the injectors spray fuel? Pull one and stick it in a glass jar and have a friend turn over the engine AFTER pull the coil to dizzy wire. Do you have spark? After putting the injector back together, grab a extra plug and pull of spark plug connector off a plug and connect it to the extra plug. Using a set of insulated pliers to grab it, ground it to the engine while a friend turns over the engine. You should have a nice bright spark on the plug. The CSV should only work at 42F and under so depending on the temp it will or won't work. Some thermo switches and thermo-time switches (which determine if the CSV will turn on) don't switch until less than 32 deg. F. I don't think mine's been cold enough to operate for 20 years! :-) Like Geoff says, first make sure you're getting spark. When you turn the key, the fuel pump runs for ~3 seconds to pressurize the fuel line. The injectors don't fire until you start cranking. If you want to see if you're getting signal to the injectors, buy a cheap "noid" light from your local auto parts store. You pull the cable going to an injector and plug in the noid light. When you crank, you should see it flashing. Spraying in some starting fluid will also help determine where your problem is. Got down to 17F in Seattle this winter and I had to look inside the plenum just to see if the CSV was working. Yep, and the 914 fires right up at that cold temp...Thank God I have the heating system working great! |
Vysoc D-Jet Troubleshooting Feb 12 2010, 07:18 AM
detoxcowboy I would test for an electrical signal at the injec... Feb 12 2010, 07:59 AM
detoxcowboy delete,, need coffee.. early 2nd post accident. Feb 12 2010, 08:00 AM
76-914 You state "it wants to fire". Have you d... Feb 12 2010, 08:30 AM
zymurgist Check the connection to the injector points (on th... Feb 12 2010, 09:36 AM
Vysoc We are receiving spark at the Injectors as we did ... Feb 12 2010, 11:58 AM
detoxcowboy
We are receiving spark at the Injectors as we did... Feb 12 2010, 12:11 PM
swl So it sounds like you have reasonably good fuel de... Feb 13 2010, 10:22 AM
vsg914 "At this point the engine wants to fire but w... Feb 13 2010, 11:00 AM
Root_Werks If the fuel lines are hooked up backwards it'l... Feb 13 2010, 11:09 AM
Vysoc Thanks for all the great information......tomorrow... Feb 17 2010, 03:01 PM
Rod Good luck, I hope it goes!
I'm not sure ... Feb 17 2010, 04:18 PM
Vysoc TODAY is NOT the day!!!
Thanks Detoxc... Feb 18 2010, 11:55 AM
pbanders
Thanks Detox... Feb 18 2010, 04:27 PM
SLITS Look for a used, but good 049 or maybe an 043 (hav... Feb 18 2010, 12:59 PM
Dave_Darling Or look through Brad's site about the internal... Feb 18 2010, 06:02 PM
pbanders
Or look through Brad's site about the interna... Feb 19 2010, 09:23 AM
Vysoc Last Post on this mess was Feb. 19. Thanks to Deto... Mar 10 2010, 07:20 PM
Vysoc THANKS ALL,
Thanks to everyone that helped at 1:... Mar 12 2010, 03:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:47 PM |
