1973 2L cyl. head sensor, wiring ? |
kwtruck |
Feb 15 2010, 02:14 PM
Newbie Group: Members Posts: 14 Joined: 27-January 10 From: cropwell, al. Member No.: 11,294 Region Association: None |
cyl. head temp sensor has 2 terminals. single wire coming out of harness. can it be altered or do I need new sensor ?
underthetire |
Feb 15 2010, 09:24 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
the only real way to use the gauge is with the thermocouple ring under the spark plug unless both your heads are tapped for the 2wire. The stock one goes in behind the rear intake tube on the passenger side. You will need it for the stock fi to work, as well as the resistor. Check http://members.rennlist.com/pbanders/ for part numbers and resistor values. The resistor can be had at radio shack.
Lo-Fi Version | Time is now: 15th June 2024 - 01:21 PM |
