> D-Jet Troubleshooting, Still no start
Vysoc
post Feb 12 2010, 07:18 AM
Vysoc
1975 - 2.0 D-Jet Stock Fuel Injection
Recently fitted with 73 GA 2.0 engine all fuel injection components are from the 75.
We have everything installed, fuel pressure through the lines is correct 28PSI, we do not seem to be receiving a signal on crank to the cold start valve, where does this signal originate?
We are also not receiving a signal to fuel injectors during cranking?
When we manually prime the plenum we can hear the injectors clicking but when we turn the key to the on position, we here the fuel pump prime but do not hear the injectors click?
At this point the engine wants to fire but will not, obviously there is not enough fuel getting to the intake?
Signal at the coil seems to be correct.
What next?
Thanks,
Vysoc (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/confused24.gif)
SLITS
post Feb 18 2010, 12:59 PM
"This Utah shit is HARSH!"
Look for a used, but good 049 or maybe an 043 (have to check compatibility).
Vysoc   D-Jet Troubleshooting   Feb 12 2010, 07:18 AM
Bleyseng   Do the injectors spray fuel? Pull one and stick it...   Feb 12 2010, 07:58 AM
pbanders   Do the injectors spray fuel? Pull one and stick i...   Feb 12 2010, 08:59 AM
Bleyseng   Do the injectors spray fuel? Pull one and stick ...   Feb 13 2010, 11:15 AM
detoxcowboy   I would test for an electrical signal at the injec...   Feb 12 2010, 07:59 AM
detoxcowboy   delete,, need coffee.. early 2nd post accident.   Feb 12 2010, 08:00 AM
76-914   You state "it wants to fire". Have you d...   Feb 12 2010, 08:30 AM
zymurgist   Check the connection to the injector points (on th...   Feb 12 2010, 09:36 AM
Vysoc   We are receiving spark at the Injectors as we did ...   Feb 12 2010, 11:58 AM
detoxcowboy   We are receiving spark at the Injectors as we did...   Feb 12 2010, 12:11 PM
swl   So it sounds like you have reasonably good fuel de...   Feb 13 2010, 10:22 AM
vsg914   "At this point the engine wants to fire but w...   Feb 13 2010, 11:00 AM
Root_Werks   If the fuel lines are hooked up backwards it'l...   Feb 13 2010, 11:09 AM
Vysoc   Thanks for all the great information......tomorrow...   Feb 17 2010, 03:01 PM
Rod   Good luck, I hope it goes! I'm not sure ...   Feb 17 2010, 04:18 PM
Vysoc   TODAY is NOT the day!!! Thanks Detoxc...   Feb 18 2010, 11:55 AM
pbanders   TODAY is NOT the day!!! Thanks Detox...   Feb 18 2010, 04:27 PM
SLITS   Look for a used, but good 049 or maybe an 043 (hav...   Feb 18 2010, 12:59 PM
Dave_Darling   Or look through Brad's site about the internal...   Feb 18 2010, 06:02 PM
pbanders   Or look through Brad's site about the interna...   Feb 19 2010, 09:23 AM
Vysoc   Last Post on this mess was Feb. 19. Thanks to Deto...   Mar 10 2010, 07:20 PM
Vysoc   THANKS ALL, Thanks to everyone that helped at 1:...   Mar 12 2010, 03:55 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:50 PM
