Hard starting when warm, 10-15 min/ stop 10 min/ hard to start |
Tom |
Sep 10 2009, 01:45 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
76 2.0 d-jet. stock displacement, hydraulics, with smog removed and backdated exhaust to 74 2.0 SSI's with Triad.
Runs great. Pulls hard to redline in 4th with no missing. Idles 850-950 when warm. Starts up when cold just great and idles 700-800. After running 10-15 minutes to town and going in the store for 10-15 minutes, come back out and turns over but doesn't want to fire. Pedal to the floor and turn over for 30-40 seconds and it gets faster and faster and finally fires up. Then runs great. If it sets for an hour or more , no problem in firing right up. Searched here and the only thing I can see that may be causing this is the distributor plate spring(s)? The wiring is all fairly new, so I don't think that would be the problem. Checked all of the connections and they are clean and tight. If the dist plate is sticking in the full advance would that give me these symptoms and how would I fix that? Grease? Special type? Thanks for any help, Tom |
tod914 |
Feb 20 2010, 09:10 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
I had a simular problem with my 1st 914. Thinking back it was definetly an electrical issue. I believe it was the ignition switch that was the culprit. Only happened after the car was warm.
computers4kids |
Feb 20 2010, 09:20 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I had a simular problem with my 1st 914. Thinking back it was definetly an electrical issue. I believe it was the ignition switch that was the culprit. Only happened after the car was warm. My 74 2.0 did that and it was the contacts in the ignition switch....heat=more resistance, perhaps that's why it's shows its ugly head when warm. I also agree with checking the coil...have you, or swap it out. My bet is on electrical. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:55 PM |
