> DJet Frustration, Ever play that Whack-A-Mole game at the arcade?
ConeDodger
post Feb 20 2010, 08:16 PM
Apex killer!
Remember that arcade game Whack-A-Mole? You take a hammer and whomp the moles as they come up through the random holes? McMark and jcd914 and me had that kind of day playing Whack-A-Mole with the DJet on Jim's engine (jcd914) in my car...
Recently the engine started running bad. It had a low speed miss and then would go like stink when you got into the advance curve. I have a bunch of new 914 DJet components so I started throwing parts at it. This is a method used by people who aren't mechanics to fix something they don't want to pay a mechanic to figure out and fix. Take a note if you aren't a mechanic - this method is often more expensive then just paying the damned mechanic. So, I replaced the MPS with one that I bought from George at AA a few years back and never really used, I replaced the harness with a Bowlsby harness, I put a resistor in the CHT circuit... Each thing I did made it run better in some ways but often worse in others.
So, I decided that since I was having the Sacramento Porsche Family Reunion today and McMark was coming up, how about having him take a look at it and paying him for his time. Mark was game. He brought his LM 1 Wideband AFR and we methodically went through the tuning process. Here is where the Whack-A-Mole game began. Everything we did would improve it but unmask some other issue. Some things did nothing when they logically should have. We replaced the distributor with a rebuilt one from Rich Bontempi, it ran worse. We discovered that two injectors were not firing. So the distributor was good but the trigger points, which were new by the way, were bad. Swapped in the trigger points from the original distributor and it ran on all cylinders again but still ran bad. Lean, very lean... Then Jim Dupree pulls in the driveway and steps out of his car with an MPS that he pulled off of one of his spares. 30 seconds to plug in the vacuum line and the harness plug and the problem is solved. Turns out the new MPS from AA is bad or badly tuned for the motor. I suspect the later as it will hold vacuum.
So after three hours of Mark's time and lots of parts. The engine - Jim's engine runs very nicely again... Ahhh... the joys of a 30+ year old car (IMG:style_emoticons/default/headbang.gif)
markb
post Feb 21 2010, 09:33 AM
914less :(
Hmmm, once I get the new 2.0 in the car, I may need to plan trip to see McMark for some tweaking to the Djet, just to get it all dialed in right. I love these threads, you keep learning new things. (IMG:style_emoticons/default/smile.gif)
ConeDodger   DJet Frustration   Feb 20 2010, 08:16 PM
Vacca Rabite   If it was easy, we'd probably get bored. Peop...   Feb 20 2010, 08:36 PM
pbanders   Good story, and you point out something that I...   Feb 21 2010, 09:00 AM
detoxcowboy   Good story, and you point out something that I...   Feb 21 2010, 10:14 AM
pbanders   Personal Parts Stash (PPS)! Every 914 owner sh...   Feb 21 2010, 10:22 AM
detoxcowboy   Personal Parts Stash (PPS)! Every 914 owner s...   Feb 21 2010, 10:49 AM
markb   Hmmm, once I get the new 2.0 in the car, I may nee...   Feb 21 2010, 09:33 AM
detoxcowboy   Took you 3 hours, probably saved you hundreds of d...   Feb 21 2010, 10:11 AM
ConeDodger   Ironically Brad, your name was mentioned during th...   Feb 21 2010, 11:14 AM
McMark   :blush: I'm just glad it's running bette...   Feb 21 2010, 11:52 AM
ConeDodger   I just got done reading Brad's section on tuni...   Feb 21 2010, 12:25 PM
dr914@autoatlanta.com   When the new MPS units were discontinued by Bosch ...   Feb 22 2010, 09:38 AM
pbanders   Good comments from George. RE: "factory speci...   Feb 22 2010, 10:52 AM
ConeDodger   Good information from both George and Brad... The...   Feb 22 2010, 12:28 PM
al weidman   Have you remembered why you had carbs. yet? :head...   Feb 23 2010, 01:51 PM
ConeDodger   Have you remembered why you had carbs. yet? :hea...   Feb 23 2010, 04:20 PM
agentblr   Maybe a stupid suggestion but have you tried a dif...   Feb 23 2010, 04:38 PM
pbanders   Maybe a stupid suggestion but have you tried a di...   Feb 23 2010, 05:18 PM
ConeDodger   Maybe a stupid suggestion but have you tried a d...   Feb 23 2010, 06:06 PM
ConeDodger   Well, we finally hit that doggone mole squarely on...   Mar 7 2010, 07:54 PM
jcd914   Years ago, I mounted the MPS to the engine tin (us...   Mar 8 2010, 12:28 AM
ConeDodger   Maybe we just laid the MPS in the engine compartm...   Mar 8 2010, 12:49 AM
pbanders   Very interesting result! From what I can tell,...   Mar 8 2010, 11:12 AM
McMark   :boing: Yippee!!   Mar 8 2010, 12:36 PM
kwales   'Tronics.. Aren't they wonderful. Electo...   Mar 8 2010, 12:48 PM
- Lo-Fi Version Time is now: 6th July 2025 - 03:31 PM
