> ATL area type IV megasquirt tuners?
thenewwazoo
post Feb 20 2010, 09:37 PM
My (fairly new-to-me) megasquirted '74 2L is running warm on the highway, and I suspect an overly aggressive ignition map might be to blame. As well, it's got some spots in the fuelling that are still rough around the edges, and I don't think I've got the patience to do anything but DRIVE the damned thing (who wants to fiddle around with the laptop when I could be enjoying the car?).
As a result, I think I'd like to buy some dyno time with a tuner that's familiar with both the type IV and the MegaSquirt... does anyone have any recommendations?
For reference, I'm tuned for ~14.5 at cruise and about 36 degrees of advance at 3100 RPM cruise on the highway. I'm seeing head temps settling around 360 with up to 385 (IMG:style_emoticons/default/unsure.gif) on long uphill sections, and oil temps of about 230. Around town temps hang out at about 345 and 225.
Thanks in advance for the advice! This forum is a really great resource.
thenewwazoo
post Feb 21 2010, 10:40 AM
That may be, but you're also selling something, and my car runs quite well otherwise. More to the point, do you know of any Atlanta-area tuners that are familiar with the MS and the type 4?
McMark
post Feb 21 2010, 11:48 AM
914 Freak!
(IMG:style_emoticons/default/agree.gif) for fuel only, you can get away with coil triggering because any fluctuations aren't nearly as pronounced as they are for ignition.
QUOTE(thenewwazoo @ Feb 21 2010, 08:40 AM) *
Once you're around here awhile, you'll understand that I'm not interested in selling anything you don't need. I was completely blown away with how much the signal improved when I switched from coil triggering to a VR sensor.
If you're car runs great without it, I'm just as happy. Your skepticism is healthy. Just keep in mind that coil triggering CAN cause erratic triggering signals, which can lead to mistimed spark events and improper fuel metering, especially at low RPM and idle.
underthetire
post Feb 21 2010, 12:08 PM
QUOTE(McMark @ Feb 21 2010, 09:48 AM) *
No sh*t. Mine was so erratic, it took the teeth right off the flywheel. Went back to just fuel, and flip the key and pretty much go. I'm currently selling of a bunch o crap to help fund my 2056 build, that will have EIDS on it.
thenewwazoo   ATL area type IV megasquirt tuners?   Feb 20 2010, 09:37 PM
kg6dxn   Are you running a MAP sensor? it sounds like you m...   Feb 20 2010, 10:07 PM
thenewwazoo   Are you running a MAP sensor? it sounds like you ...   Feb 20 2010, 10:10 PM
brer   hey, would be at all interested in sharing some 9...   Feb 20 2010, 10:47 PM
underthetire   hey, would be at all interested in sharing some ...   Feb 20 2010, 10:52 PM
904svo   I live in wodstock am I still trying to get my Meg...   Feb 21 2010, 08:31 AM
McMark   I'm a huge proponent of crank triggering for M...   Feb 21 2010, 10:37 AM
underthetire   I'm a huge proponent of crank triggering for ...   Feb 21 2010, 10:45 AM
thenewwazoo   That may be, but you're also selling something...   Feb 21 2010, 10:40 AM
McMark   :agree: for fuel only, you can get away with coil ...   Feb 21 2010, 11:48 AM
underthetire   :agree: for fuel only, you can get away with coil...   Feb 21 2010, 12:08 PM
thenewwazoo   ... especially at low RPM and idle. Okay, well,...   Feb 21 2010, 05:22 PM
DBCooper   :agree: for fuel only, you can get away with coil...   Feb 21 2010, 05:32 PM
904svo   I'm running Megasquirt with a 36-1 tooth wheel...   Feb 21 2010, 04:10 PM
underthetire   I'm running Megasquirt with a 36-1 tooth whee...   Feb 21 2010, 04:35 PM
904svo   I'm running Megasquirt with a 36-1 tooth whe...   Feb 21 2010, 05:20 PM
underthetire   [quote name='underthetire' post='1276811' date='F...   Feb 21 2010, 05:24 PM
John Jentz   I'm running Megasquirt with a 36-1 tooth whe...   Feb 21 2010, 05:42 PM
BIGKAT_83   Should be no trouble finding someone in Atlanta to...   Feb 21 2010, 05:46 PM
904svo   My (fairly new-to-me) megasquirted '74 2L is ...   Feb 21 2010, 08:58 PM
thenewwazoo   Type 4 like to run about 13:1 to stay cool at tho...   Feb 21 2010, 09:25 PM
kg6dxn   try this link http://914megasquirt.ning.com/   Feb 21 2010, 10:09 PM
brer   try this link http://914megasquirt.ning.com/ y...   Feb 22 2010, 12:37 PM
Jake Raby   I'm no fan of MS, but I'd be happy to assi...   Feb 21 2010, 10:28 PM
thenewwazoo   I'm no fan of MS, but I'd be happy to ass...   Feb 22 2010, 01:01 PM
Al Meredith   I think in your first post you said you were runni...   Feb 22 2010, 12:52 PM
thenewwazoo   I think in your first post you said you were runn...   Feb 22 2010, 01:05 PM
toon1   My (fairly new-to-me) megasquirted '74 2L is ...   Feb 22 2010, 06:41 PM
Jake Raby   I agree.. Over-advancing is pretty easy to do, esp...   Feb 23 2010, 02:22 PM
underthetire   While I agree with both of you, 36 is too much, it...   Feb 23 2010, 02:35 PM
thenewwazoo   Cool - I've got an appointment with Dean @ Rab...   Feb 23 2010, 02:56 PM
Jake Raby   . We'll see you then. Have the engine tuned...   Feb 23 2010, 03:29 PM
904svo   Jake, are on lookers allowed to watch?   Feb 23 2010, 04:01 PM
Jake Raby   Jake, are on lookers allowed to watch? [u][size...   Feb 23 2010, 04:16 PM
thenewwazoo   Man, that was great! Jake let me invite all my...   Mar 17 2010, 02:07 PM
Jake Raby   Glad to see the car is better than it was when you...   Mar 17 2010, 03:25 PM
JamesM   Did the tuning help with the head temps? Also, wh...   Mar 17 2010, 07:21 PM
thenewwazoo   Did the tuning help with the head temps? Also, w...   Mar 17 2010, 08:57 PM
904svo   If you are using a FI cam, you may have to rebuild...   Mar 17 2010, 08:05 PM
thenewwazoo   If you are using a FI cam, you may have to rebuil...   Mar 17 2010, 08:58 PM
904svo   If you are using a FI cam, you may have to rebui...   Mar 17 2010, 09:22 PM
thenewwazoo   The tables are 12X12 or 8x8. If you don't use...   Mar 17 2010, 09:26 PM
904svo   [quote name='904svo' post='1288347' date='Mar 17 ...   Mar 17 2010, 09:45 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:50 AM
