Hard starting when warm, 10-15 min/ stop 10 min/ hard to start |
Tom |
Sep 10 2009, 01:45 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
76 2.0 d-jet. stock displacement, hydraulics, with smog removed and backdated exhaust to 74 2.0 SSI's with Triad.
Runs great. Pulls hard to redline in 4th with no missing. Idles 850-950 when warm. Starts up when cold just great and idles 700-800. After running 10-15 minutes to town and going in the store for 10-15 minutes, come back out and turns over but doesn't want to fire. Pedal to the floor and turn over for 30-40 seconds and it gets faster and faster and finally fires up. Then runs great. If it sets for an hour or more , no problem in firing right up. Searched here and the only thing I can see that may be causing this is the distributor plate spring(s)? The wiring is all fairly new, so I don't think that would be the problem. Checked all of the connections and they are clean and tight. If the dist plate is sticking in the full advance would that give me these symptoms and how would I fix that? Grease? Special type? Thanks for any help, Tom |
Tom |
Feb 21 2010, 12:32 PM
Thanks for the replys.
Don't think the ignition switch is bad. The hard to stsrt issue comes into play after sitting for 10-15 minutes. Since the switch is in the passenger comp, it should cool rather quicky. I am using logical trouble shooting methods here and maybe that is part of the problem. I rebuilt the ignition harness using new teflon coated wire and all new connectors, so I'm pretty sure that isn't the problem. I guess the next step is to take some voltage readings while starting cold and then more when the hard to start problem is there and compare the readings. I'll post the findings when I have them. Not the cold start valve as I have the pressure gage hooked up there now. I'm surprised that this doesn't have a more widely known cure since it has been around since the cars were new? Tom |
Lo-Fi Version | Time is now: 9th June 2024 - 03:43 PM |
