| thenewwazoo |
Feb 20 2010, 09:37 PM
Member ![]() ![]() Group: Members Posts: 56 Joined: 3-October 09 From: RWC Member No.: 10,883 Region Association: Northern California |
My (fairly new-to-me) megasquirted '74 2L is running warm on the highway, and I suspect an overly aggressive ignition map might be to blame. As well, it's got some spots in the fuelling that are still rough around the edges, and I don't think I've got the patience to do anything but DRIVE the damned thing (who wants to fiddle around with the laptop when I could be enjoying the car?).
As a result, I think I'd like to buy some dyno time with a tuner that's familiar with both the type IV and the MegaSquirt... does anyone have any recommendations? For reference, I'm tuned for ~14.5 at cruise and about 36 degrees of advance at 3100 RPM cruise on the highway. I'm seeing head temps settling around 360 with up to 385 (IMG:style_emoticons/default/unsure.gif) on long uphill sections, and oil temps of about 230. Around town temps hang out at about 345 and 225. Thanks in advance for the advice! This forum is a really great resource. |
| Mike Bellis |
Feb 21 2010, 10:09 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
| brer |
Feb 22 2010, 12:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
yes but don't expect miracles just yet as i'm in the same boat as you. :-) but do share your experience on jakes dyno. |
thenewwazoo ATL area type IV megasquirt tuners? Feb 20 2010, 09:37 PM
kg6dxn Are you running a MAP sensor? it sounds like you m... Feb 20 2010, 10:07 PM
thenewwazoo
Are you running a MAP sensor? it sounds like you ... Feb 20 2010, 10:10 PM
brer hey, would be at all interested in sharing some 9... Feb 20 2010, 10:47 PM
underthetire
hey, would be at all interested in sharing some ... Feb 20 2010, 10:52 PM
904svo I live in wodstock am I still trying to get my Meg... Feb 21 2010, 08:31 AM
McMark I'm a huge proponent of crank triggering for M... Feb 21 2010, 10:37 AM
underthetire
I'm a huge proponent of crank triggering for ... Feb 21 2010, 10:45 AM
thenewwazoo That may be, but you're also selling something... Feb 21 2010, 10:40 AM
McMark :agree: for fuel only, you can get away with coil ... Feb 21 2010, 11:48 AM
underthetire
:agree: for fuel only, you can get away with coil... Feb 21 2010, 12:08 PM
thenewwazoo
... especially at low RPM and idle.
Okay, well,... Feb 21 2010, 05:22 PM
DBCooper
:agree: for fuel only, you can get away with coil... Feb 21 2010, 05:32 PM
904svo I'm running Megasquirt with a 36-1 tooth wheel... Feb 21 2010, 04:10 PM
underthetire
I'm running Megasquirt with a 36-1 tooth whee... Feb 21 2010, 04:35 PM
904svo
I'm running Megasquirt with a 36-1 tooth whe... Feb 21 2010, 05:20 PM
underthetire
[quote name='underthetire' post='1276811' date='F... Feb 21 2010, 05:24 PM
John Jentz
I'm running Megasquirt with a 36-1 tooth whe... Feb 21 2010, 05:42 PM
BIGKAT_83 Should be no trouble finding someone in Atlanta to... Feb 21 2010, 05:46 PM
904svo
My (fairly new-to-me) megasquirted '74 2L is ... Feb 21 2010, 08:58 PM
thenewwazoo
Type 4 like to run about 13:1 to stay cool at tho... Feb 21 2010, 09:25 PM
Jake Raby I'm no fan of MS, but I'd be happy to assi... Feb 21 2010, 10:28 PM
thenewwazoo
I'm no fan of MS, but I'd be happy to ass... Feb 22 2010, 01:01 PM
Al Meredith I think in your first post you said you were runni... Feb 22 2010, 12:52 PM
thenewwazoo
I think in your first post you said you were runn... Feb 22 2010, 01:05 PM
toon1
My (fairly new-to-me) megasquirted '74 2L is ... Feb 22 2010, 06:41 PM
Jake Raby I agree.. Over-advancing is pretty easy to do, esp... Feb 23 2010, 02:22 PM
underthetire While I agree with both of you, 36 is too much, it... Feb 23 2010, 02:35 PM
thenewwazoo Cool - I've got an appointment with Dean @ Rab... Feb 23 2010, 02:56 PM
Jake Raby .
We'll see you then.
Have the engine tuned... Feb 23 2010, 03:29 PM
904svo Jake, are on lookers allowed to watch? Feb 23 2010, 04:01 PM
Jake Raby
[u][size... Feb 23 2010, 04:16 PM
thenewwazoo Man, that was great! Jake let me invite all my... Mar 17 2010, 02:07 PM
Jake Raby Glad to see the car is better than it was when you... Mar 17 2010, 03:25 PM
JamesM Did the tuning help with the head temps? Also, wh... Mar 17 2010, 07:21 PM
thenewwazoo
Did the tuning help with the head temps? Also, w... Mar 17 2010, 08:57 PM
904svo If you are using a FI cam, you may have to rebuild... Mar 17 2010, 08:05 PM
thenewwazoo
If you are using a FI cam, you may have to rebuil... Mar 17 2010, 08:58 PM
904svo
If you are using a FI cam, you may have to rebui... Mar 17 2010, 09:22 PM
thenewwazoo
The tables are 12X12 or 8x8. If you don't use... Mar 17 2010, 09:26 PM
904svo
[quote name='904svo' post='1288347' date='Mar 17 ... Mar 17 2010, 09:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:48 AM |
